16F872 and interrupt handling
Results 1 to 11 of 11
    Jun 2007
    Germany
    Ok Darrel i´ve found the error.
    I changed the program like this and it´s working perfect.
    DISABLE
    myint:
    RBCpins = PORTB
    INTCON.0 = 0
    if rbcpins.7 <> Lastpins.7 then
    dpo1 = 0
    for lp = 0 to 20
    pause 1
    next lp
    dpo2 = 0
    for lp = 0 to 40
    pause 1
    next lp
    dpo1 = 1
    dpo2 = dpo1
    if rbcpins.6 <> lastpins.6 then
    dpo2 = 0
    for lp = 0 to 20
    pause 1
    next lp
    dpo1 = 0
    for lp = 0 to 40
    pause 1
    next lp
    dpo2 = 1
    dpo1 = dpo2
    RESUME
    ENABLE
    Maybe the error comes from the subroutine. I include the subroutine directly and it works fine.
    Thanks a lot Darrel
    PS: How you insert a code in a window like you posted it before ?
    Using [code][/code] tags puts it in a window.
    At the bottom of the page, there's a box that says "Posting Rules". Inside that there's a link to vB code. Check it out. You can do all kinds of formatting.
    hth,
    Darrel and ON INTERRUPT in the same thread ???
    Well, I figure you can't appreciate "Instant Interrupts" until you've had to deal with ON INTERRUPT a few times.
    Got to get them started.
    I wish Melabs would be willing to replace ON INTERRUPT with DT-INT... man you have to talk to them
    Another compiler use something around that... you know which one
    Jul 2007
    is it possible to use a momentary switch (operating on 5v) as a digital input? so I can use interrupts.
  1. @Darrel Taylor Interrupt ;-)
    By Robson in forum mel PIC BASIC Pro
    Last Post: - 31st August 2007, 01:59
