16F872 and interrupt handling
Results 1 to 11 of 11
    Jun 2007
    Germany
    Thanks Daylor.
    I`ll try to insert your program into my.
    Jun 2007
    Germany
    Hello Darrel,
    now the interrupt works fine, but after interrupt the pic hangs. I need to reset it. Can you tell me where is the failure ?
    code:
    ADCON1 = %111
    define OSC 4
    TRISA = %00111000 ' RA0-2 OUT, RA3-5 INPUT
    TRISB = %11000000 ' OUTPUT
    TRISC = %00000000 ' OUTPUT
    col1 var PORTA.0
    col2 var PORTA.1
    col3 var PORTA.2
    row1 var PORTA.3
    row2 var PORTA.4
    row3 var PORTA.5
    id1 var PORTB.7 ' Input1 Rotary
    id2 var PORTB.6 ' Input2 Rotary
    click var PORTB.5
    tp var PORTB.4
    tm var PORTB.3
    vm var PORTC.0
    vp var PORTC.1
    unt var PORTC.2
    srcl var PORTC.3
    srcr var PORTC.4
    dp4 var PORTC.5
    dp3 var PORTC.6
    dp2 var PORTC.7
    dpo1 var PORTB.2 ' Simulation OUT 1
    dpo2 var PORTB.1 ' Simulation OUT 2
    summer var PORTB.0 ' Beep active
    lp var word
    drehpos var byte
    savepos var byte
    cnt var byte
    ums var bit
    delay var word
    startclk var word
    RBCPins var Byte
    LastPins var Byte
    Lastpins = PORTB
    INTCON.0 = 0
    INTCON.3 = 1
    on interrupt goto myint
    GOTO main
    switchd:
    dpo2 = 0
    for lp = 0 to 20
    pause 1 ' Time for Simulation 20ms
    next lp
    dpo1 = 0
    for lp = 0 to 40
    pause 1 ' 40ms Pause
    next lp
    dpo2 = 1 : dpo1 = 1
    switchh:
    dpo1 = 0
    for lp = 0 to 20
    next lp
    dpo2 = 0
    for lp = 0 to 40
    next lp
    dpo1 = 1 : dpo2 = 1
    DISABLE
    myint:
    RBCpins = PORTB
    INTCON.0 = 0
    if RBCpins.7 <> Lastpins.7 then
    Lastpins.7 = rbcpins.7
    gosub switchh
    if RBCpins.6 <> Lastpins.6 then
    lastpins.6 = rbcpins.6
    gosub switchd
    resume
    enable
    Somehow, the RESUME got moved inside the IF statement.
    The only way it will resume is if PORTB.6 changes.
    Otherwise it falls off into never never land.
    Jun 2007
    Germany
    Ok Darrel i´ve found the error.
    I changed the program like this and it´s working perfect.
    DISABLE
    myint:
    RBCpins = PORTB
    INTCON.0 = 0
    if rbcpins.7 <> Lastpins.7 then
    dpo1 = 0
    for lp = 0 to 20
    pause 1
    next lp
    dpo2 = 0
    for lp = 0 to 40
    pause 1
    next lp
    dpo1 = 1
    dpo2 = dpo1
    if rbcpins.6 <> lastpins.6 then
    dpo2 = 0
    for lp = 0 to 20
    pause 1
    next lp
    dpo1 = 0
    for lp = 0 to 40
    pause 1
    next lp
    dpo2 = 1
    dpo1 = dpo2
    RESUME
    ENABLE
    Maybe the error comes from the subroutine. I include the subroutine directly and it works fine.
    Thanks a lot Darrel
    PS: How you insert a code in a window like you posted it before ?
    Using [code][/code] tags puts it in a window.
    At the bottom of the page, there's a box that says "Posting Rules". Inside that there's a link to vB code. Check it out. You can do all kinds of formatting.
    hth,
    Darrel and ON INTERRUPT in the same thread ???
    Well, I figure you can't appreciate "Instant Interrupts" until you've had to deal with ON INTERRUPT a few times.
    Got to get them started.
  1. @Darrel Taylor Interrupt ;-)
    By Robson in forum mel PIC BASIC Pro
    Last Post: - 31st August 2007, 01:59
