Driving a Voltage Regulator with PWM
Results 1 to 9 of 9
    SWITZERLAND (french speaking)
    Default Some theory
    Thanks BrianT,
    Yes, I use the CCP1 pin for HWPM.
    So, it would look like this:
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1803&stc=1&d=118292364 8">
    Brian, may I kindly ask to you to explain the time constant calculation and relation to the PWM frequency? This is not clear to me as I do this usually on the "thumb" (= au pifomètre).
    In fact, I made this circuit already (had a 47u cap) and could not vary the output voltage very well. But I thought this was because I adjusted the VR in "voltage" instead of "current" mode.
    The voltage would change only from around 120 to 240 dutycycle (CPP1RL) and I would read between 3V and 4V.
    I also corrected the output voltage on the schema...
    Roger
    Jan 2006
    Istanbul
    1. Why not using a digital POT?
    2. Also, in the schema above, there should be a resistor parallel to C1 cap.
    Default any suggestion
    Hi Sayzer,
    To me, HPWM looks simple. But, as you say, why not another way?
    Never used a Digital pot before. What "resolution" (roughtly voltage step) will I get?
    Any suggestion of values I should use in this case and what the schema would then look like?
    If I stick to the HPWM, what value should I use for the resistor to be put parallel to the cap?
    Thank you in advance
    Roger
    I think that the PIC is in danger by that connection. If your supply is 12V and the output around 2, the rest 10 volts should be between regulators ground pin and ground. So the output of the PIC is at high voltage point through the resistor.
    What exactly are the specs? What do you want to produce at the output?
    My suggestion could be something like this:
    1. PIC HPWM to a filter.
    2. Filter to an Opamp for DC voltage amplifying.
    3. Power output Transistor to give the appropriate current to the load.
    You can produce a 0-12 output that way.
    If you want controlled Current source then the Pass transistor could be at the feed back loop of the opamp. I'll try to scetch and scan if needed.
    Default This meant for a battery charger
    Hi Ioannis,
    I am making a lead-batteries charger.
    In my opinion, it is not necessary to control the full voltage range of the batteries that need to be charged.
    Important is to control the charging voltage (2,35V/element), the floating voltage (2,26V/element) and, of course, the timing (n hours for charging -depending on battery capacity- and then go to "float" or "trickle" mode).
    So, if you have i.e. a 12V lead-battery (= 6 elements), the charging voltage will be 6x2,35V=14,1V and the floating voltage will be 6x2,26V=13,56V.
    Roughtly, the voltage range to control is quite narrow: less than 1 volt. Thus. this should avoid the use of an OP-Amp. The current is limited by the transformer's capacity.
    So this is what I would like to achieve now. It could look like this:
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1806&stc=1&d=118293647 1">
    Roger
    On the schematic you have to power with more that 15Volts. 2950-5 needs at least 0.45 volts at the input above from 5V. If your battery is discharged and request more current, the transformer might drop the voltage bellow 15V.
    The circuit is quite economical but I am afraid that is quite a compromise too.
    I have attached my idea in a hand schetch (sorry, no CAD here!).
    CAD is not necessary - your drawing is well done
    You're right, the Zener is going to be an 8,7V since I don't have another under my hand...
    Maybe I'll go for your solution.
    Have to make some trials.
    Thanks a lot.
    Roger
  1. Variable PWM PIC18F2431
    By trr1985 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2009, 06:03
  2. Voltage monitor and PWM control
    By StoneColdFuzzy in forum mel PIC BASIC Pro
    Last Post: - 11th May 2009, 16:11
  3. Negative voltage for LCD driving?
    By Fredrick in forum Schematics
    Last Post: - 15th January 2009, 11:51
  4. PIC driving Adjustable Voltage Regulator
    Last Post: - 6th June 2007, 20:05
  5. Help with final project
    By OvERKiLL in forum General
    Last Post: - 15th December 2006, 20:35
