Driving a Voltage Regulator with PWM
Results 1 to 9 of 9
    SWITZERLAND (french speaking)
    Default Driving a Voltage Regulator with PWM
    Hello,
    Does anyone have a very simple example on how to drive (adjust) a Voltage Regulator with PWM?
    I have a +5V LM340 VR and don't know how to connect it to make it Current driven.
    This is what I built (simplified here) and this won't work for sure.
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1793&stc=1&d=118289009 9">
    How do I do this a correct way?
    Roger
    Default Needs RC filter
    I assume the PIC pin joining the 12F683 to the junction of the 10k, 2k2 and 100nF is the PWM out of the PIC.
    What you need from the PIC HPWM is a series resistor - say 1K, then a large cap to ground, say 100 uF. This time constant is 100 mSecs so the HPWM frequency should be at least 1 kHz. The junction of the 1k/100uF then goes to the ground pin on the regulator.
    HTH
    Brian
    Default Some theory
    Thanks BrianT,
    Yes, I use the CCP1 pin for HWPM.
    So, it would look like this:
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1803&stc=1&d=118292364 8">
    Brian, may I kindly ask to you to explain the time constant calculation and relation to the PWM frequency? This is not clear to me as I do this usually on the "thumb" (= au pifomètre).
    In fact, I made this circuit already (had a 47u cap) and could not vary the output voltage very well. But I thought this was because I adjusted the VR in "voltage" instead of "current" mode.
    The voltage would change only from around 120 to 240 dutycycle (CPP1RL) and I would read between 3V and 4V.
    I also corrected the output voltage on the schema...
    Roger
    Jan 2006
    Istanbul
    1. Why not using a digital POT?
    2. Also, in the schema above, there should be a resistor parallel to C1 cap.
    Default any suggestion
    Hi Sayzer,
    To me, HPWM looks simple. But, as you say, why not another way?
    Never used a Digital pot before. What "resolution" (roughtly voltage step) will I get?
    Any suggestion of values I should use in this case and what the schema would then look like?
    If I stick to the HPWM, what value should I use for the resistor to be put parallel to the cap?
    Thank you in advance
    Roger
    I think that the PIC is in danger by that connection. If your supply is 12V and the output around 2, the rest 10 volts should be between regulators ground pin and ground. So the output of the PIC is at high voltage point through the resistor.
    What exactly are the specs? What do you want to produce at the output?
    My suggestion could be something like this:
    1. PIC HPWM to a filter.
    2. Filter to an Opamp for DC voltage amplifying.
    3. Power output Transistor to give the appropriate current to the load.
    You can produce a 0-12 output that way.
    If you want controlled Current source then the Pass transistor could be at the feed back loop of the opamp. I'll try to scetch and scan if needed.
  1. Variable PWM PIC18F2431
    By trr1985 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2009, 06:03
  2. Voltage monitor and PWM control
    By StoneColdFuzzy in forum mel PIC BASIC Pro
    Last Post: - 11th May 2009, 16:11
  3. Negative voltage for LCD driving?
    By Fredrick in forum Schematics
    Last Post: - 15th January 2009, 11:51
  4. PIC driving Adjustable Voltage Regulator
    Last Post: - 6th June 2007, 20:05
  5. Help with final project
    By OvERKiLL in forum General
    Last Post: - 15th December 2006, 20:35
