Restart 18F2620
Results 1 to 9 of 9
Thread: Restart 18F2620
    Sep 2005
    Dayton, Ohio
    Peter, yes I would say that is correct (or at least one way to do it). I suppose there are no hard and fast rules per se, but any Programming 101 professor would surely beat us with a stick for exiting a GOSUB with a GOTO rather than RETURN with a flag set or some other method.
    CCK, Same here, I spent MANY hours headscratching over that one. Until I discovered that the processor always reset after exactly the same number of calls to a certain subroutine. Lots of time spent reading the datasheets/forums too. All resulting from poor (untrained) programming practices/bad habits. But learned a LOT in the process. 18F definitely has a few "gotchas" when migrating.
    Jim Robertson
    "MilesTag" DIY Lasertag
    www.lasertagparts.com/mtdesign.htm
    Dayton, Ohio
    Thank you for the fast replies guys. Are you also saying that if you don't cancel a gosub with a return on the 16F parts, it doesn't matter? I am not in the habit of doing this but, as a quick fix to a program, it would be handy to know. I was told it will eventually cause a stack overflow on any PIC. Thank you. - Peter
    sinoteq's Avatar
    sinoteq Guest
    You could test to disable the Stack reset in the configuration bits, that should prevent the MCU from doing a reset when doing a stack under- or overflow. Simple and easy but be aware that a return later in the code can make stange things. Page 253 in the manual if you want to look CONFIG4L register.
    Mar 2005
    Smile
    Power supply: 3.6V current peaks of up to 2° and a maxximum voltage drop of 300mV durino transmission burst. Local power source feeds the Q2501 module and the PIC 18f2620.
    Connection MCLRE pin – Diode –R 11Kohm – Vcc. I use one breadboard.
    Hour we come to the good news: inserted condenser from 0,1 uf. They are some hours that software turn without restart. The strange characters between the PIC and the PC are passings also. Thanks. Perhaps resolved problem
  1. In Circut Debug (ICD) buttons palet is disable for 18F2620
    By muskut in forum mel PIC BASIC Pro
    Last Post: - 17th June 2010, 06:21
  2. 18F2620 tmr0 and interrupts
    By astouffer in forum mel PIC BASIC Pro
    Last Post: - 8th March 2009, 01:56
  3. X-10 and the proper XOUT statement for 18F2620
    By JohnP in forum mel PIC BASIC Pro
    Last Post: - 10th December 2007, 23:04
  4. 18F2620 compile problems in PBP
    By Joe Rocci in forum mel PIC BASIC Pro
    Last Post: - 13th August 2006, 11:11
  5. How can I find Code Loader 18F2620 files ?
    By muskut in forum General
    Last Post: - 14th October 2005, 13:26
