Servo loosing my mind...
Results 1 to 8 of 8
    Default Servo loosing my mind...
    Ok I'm loosing my mind here!
    The code below works fine sorta.
    @ __CONFIG _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_ON & _MCLRE_OFF & _BODEN_ON
    DEFINE OSCCAL_1K 1
    INCLUDE "modedefs.bas"
    TRISIO.0 = 0         'Set GPIO.0 to output.
    ANSEL = 0            'disable ADCs
    CMCON = 7            'disable comparator
    T1CON = %00000110
    ANSEL.1 = 0    'Set GPIO.1 to digital
    Pulselen     Var byte
    ValidCode    Var byte
    I            var byte
    clear
    validcode=200
    If validcode=200 then
       for I = 1 to 20
       Pulsout GPIO.0, 200
       next I
       validcode=0
    Whats happening is I compiled it and have a hex file. I load it into flash kit starter, came with my pic kit V1
    I burn a chip
    12F675 and half the time it sends out a .005ms pulse instead of a 2 ms pulse.
    If I take the same chip reburn it, it works maybe if not reburn it and it works...
    What am I doing wrong here that sometimes works perfectly and others not? I'm using the same hex file...
    Any ideas?
    What is it you want the code to do?
    You have a FOR-NEXT Loop with PULSOUT but you dont have any PAUSE in there so basicly there will be 20 2mS pulses right after each other with very little time between them. These 20 pulses will be present on the pin for roughly 40mS and then they will stop because you set Validcode to 0 after 20 pulses. So is it possible that you miss seeing the pulses all together?
    HTH
    /Henrik Olsson.
    Thanks for the reply. What I was acutally tying to accomplish is a servo pulse of 2mS that should repeat every 20mS.
    This should basically be a full one way signal for a servo.
    I realize now that I didn't have a delay but still when I hook this to my scope
       for I = 1 to 20
       Pulsout GPIO.0, 200
       pause 18
       next I
    I don't get a nice clean 2mS square like I see from a known servo signal.
    Why not just use a plain ol' pause statement for the testing part of your project? It'll at least eliminate the possibility of pulsin causing your problem.
    gpio.0 = 1
    pause 2
    gpio.0 = 0
    pause 2 (then switch it over to 18 after you've verified a good square wave)
    It's basically the same ol' blinky led program, but it'll get the ball rolling...
    Yes but you will still only get 20 pulses because of the FOR-NEXT lopp. What if you try this:
    GPIO.0 = 0
       Pulsout GPIO.0, 200
       pause 18
    Goto Main
    /H.O
    New Zealand
    are you scoping it with the servo connected? Servos can put out some pretty nasty noise when running - and need to be seperatly regulated and filtered
    Default Preset state of Pulsout pin PLUS add a pause
    Yes you need a pause to pace the servo pulses to approximately 50 per second. In addition, note that Pulsout is only a toggle. Unless you force the pin to a zero at the start of the loop, there is a good chance that sometimes the line will idle high instead of idling low. That drives a servo nuts.
    Try
    for i = 0 to 20
    low servopin
    pulseout servopin, 200
    pause 18
    next i
    Note that 95+% of the time you may get away without forcing the servopin low but there WILL be times when the line idles high. It cost me a plane crash.
    HTH
    Brian
    May 2006
    Kedah, Malaysia
    Geckorotto do you connect the servo directly to batteries or you use a LM7805 regulator?
    for I = 1 to 20
    Pulsout GPIO.0, 200
    pause 18
    next I
    This code should work fine. Sometime servo become nut because of the current is not enough.
    That is base on my experience.
  1. More Servo Woes
    By chrisshortys in forum mel PIC BASIC Pro
    Last Post: - 13th May 2009, 08:40
  2. Problem with 12F629, servo and EEPROM
    By Atom058 in forum mel PIC BASIC Pro
    Last Post: - 1st March 2008, 09:53
  3. Servo does not move
    By ruijc in forum General
    Last Post: - 12th November 2007, 19:14
  4. Beginner + Servo
    By james in forum mel PIC BASIC Pro
    Last Post: - 31st July 2007, 21:31
  5. Help with Servo Control Please!
    By wireman22 in forum mel PIC BASIC Pro
    Last Post: - 7th June 2007, 18:15
