Sending printer "Esc/Pos" commands
Results 1 to 3 of 3
    Angry Sending printer "Esc/Pos" commands
    I have a serial reciept printer, Its working fine with normal text. using the Serial out command.
    I would like to use some of the advance features like the "Underline, Double-strike" modes.
    The ansi commands are "ESC -" ( 1B 2D hex) to turn underline mode on/off, and "ESC G" ( 1B 47 hex) to Turn double-strike mode on/off.
    How can I send the commands using SerOut ?
    Help Please
    Quote Originally Posted by Kman View Post
    Help Please
    Have you tried something silly, such as, oh, I don't know...checking the manual for syntax?
    serout seroutpin, n2400, [ 27 , 45 ] -there's your underline mode on/off
    You figure out the rest...
    Thanks Skimask, the printer was defaulting to a special mode that would not eccept any "Esc" commands. Sending a $28 hex put the printer into a navative mode witch im getting a few of the commands to work.
    I Think I found a use for that 12c508a ( send FS command when the printer powers up )
    Kman
  1. Anybody used EPSON M-42V Daisy wheel Printer
    By sougata in forum mel PIC BASIC Pro
    Last Post: - 7th September 2009, 20:58
  2. Sending Commands from Visual Basic about IR to Pic
    By tne_de in forum mel PIC BASIC Pro
    Last Post: - 29th April 2009, 06:09
  3. Sending AT Commands using SEROUT
    By stuart_penman in forum mel PIC BASIC Pro
    Last Post: - 9th May 2008, 20:38
  4. Using LPT port dot matrix printer with PIC
    Last Post: - 27th January 2007, 11:48
  5. Sending data over USB via VB
    Last Post: - 12th September 2005, 01:00
