122x32 GLCD basic code
Results 1 to 18 of 18
    Jan 2008
    lincoln uk
    Default Using LCD graphic 132x32 display KS0713
    I have a few of 132x32 LCD modules which use a KS0713 controller.
    Does someone have some simple PICBasic Pro code I could try out on one of them.
    I have used 2x20 displays OK but want to expand my knowledge a bit.
    Much appreciated
    Mike, med2007
    ------ forgive me.. not seems to be compatible after all ------
    Jan 2008
    lincoln uk
    Default GLCD 132x32
    What is not compatible?
    Rgds
    Quote Originally Posted by med2007 View Post
    Rgds
    Looks like they're compatible enough....maybe just not for your SPECIFIC application.
    The commands have basically the same bit patterns. There will need to be some changes in the source code because of the different numbers of pixels (122 vs. 132), but otherwise, it looks to be pretty much the same sort of thing.
  1. Code doesn't work on 16F648A
    By Mr_Joe in forum mel PIC BASIC Pro
    Last Post: - 1st September 2018, 23:09
  2. 18F4550 Bootloader enter via eeprom setting
    By bradb in forum mel PIC BASIC Pro
    Last Post: - 23rd November 2008, 00:51
  3. Making Program Code Space your playground...
  4. ASM Interrupts with BASIC code?
    By Desterline in forum mel PIC BASIC Pro
    Last Post: - 31st October 2003, 20:21
  5. Help with MPASM and PIC Basic
    By johngb in forum mel PIC BASIC Pro
    Last Post: - 21st February 2003, 14:07
