Hello Clinton,
I don't know if you are aware that there are quite a few variations of the Basic language for PICs. OshonSoft's is different from MELabs which is what this forum is for. I would suggest you check out www.oshonSoft.com and see if they have a forum that might be able to help you. There also may be someone on this forum that uses both PBP here and the variation from OshonSoft that hasn't seen this post yet. OshonSoft's big claim is their simulator that allows you to see how your program will run on a PC display with an IDE for around $20.00.
Keep checking this site to see if someone is able to help you. Good luck in your venture!
BobK
