Newbie HPWM / ADC question
Results 1 to 9 of 9
    Wink
    Hi, Johan
    For what you do at this time ... no great difference !!!
    Note HPWM Always use 8 bits...
    but why use 10 bits resolution to divide the result afterwards ... ( note here it's a division by 4 or two times right shifting !!! ).
    Here, with 8 bits, ADC result is faster given, no need to add complementary formatting and no need to use an intermediate variable ( "pwmduty" can be replaced by "analogvalue" )
    add to this your variables can be only BYTES ... so you spare lots of room !!!
    Note also ADCON1.7 must be set to LEFT Justification ( "0" for BYTE result )
    One habit I have is NOT to change HPWM if pwmduty doesn't change ... that saves also time for other stuff ... and response to pot change is faster.
    Also always give initial values to variables ( CLEAR, if all = 0 )
    so, gives at last ...
    DEFINE OSC 4 ' Clock 4 Mhz
    DEFINE ADC_BITS 8 ' ADC resolution 10 bit
    DEFINE ADC_CLOCK 3 ' Set clock source (rc = 3)
    DEFINE ADC_SAMPLEUS 50 ' Sampling time 50ms
    OSCCON = $60 ' Internal oscillator frequency 4 Mhz
    ANSEL = %01111011 ' Analog channel 0,1,3-7 Digital channel 2,8
    ADCON1 = %00000000 ' VDD & VSS as VREF
    PORTA = %00000000
    PORTB = %00000000
    TRISA = %11111111 ' Set PORTA to all input
    TRISB = %00000000 ' Set PORTB to all output
    analogport VAR PORTA.0 ' Analog port pin RA.0
    analogvalue VAR BYTE ' Value digital 0 - 255
    oldanalogvalue VAR BYTE
    CLEAR
    ADCIN analogport,analogvalue
    IF analogvalue = oldanalogvalue THEN Jump
    hpwm 1,analogvalue,7800
    oldanalogvalue = analogvalue
    Jump:
    Hope I didn't forget anything ... LOL
    Jun 2007
    Default PORTA.1 not working ?
    Hi Alain,
    I got another problem :
    If I try to read from PORTA.1 and change the code accordingly ( analogport var porta.1 )
    HPWM does not function, it just send output at 50% regardless the position of the pot
    Anything I set wrong?
    Wink the debug sequence ...
    Hi, Johan
    When happening ... the first reflex is to open the datasheet and look to the functions connected to the "faulty" pins ...
    have a look to pict $ 5.1 ...
    Here we also find an ANALOG Comparator ...
    so, let's disable it !!!
    CMCON = 7 ( from the table $13.1 )
    By the way, we don't need the voltage ref nor ...
    CVRCON = 0
    So, I did forget some littles things ??? ...
    Jun 2007
    Default Still does not work
    Hi Alain,
    On table 13.1 : The value on POR, register CMCON is 7 & CVRCON is 0, do we really need to change ?
    I did put CMCON = 7 and CVRCON =0 , but there was no difference
    The strange thing: If I put 2 pots ( one on RA0, one on RA1), the PIC read value on PORTA.0 only ( How come ??? I did not even put ADC command on RA0 )
    Johan
    Wink
    Hi,Johan,
    You're right for CMCON ... there's some overhead here, but Melabs recommends to set it in the program beginning ...
    and we all trust in Melabs !!!
    WOW ... Got it for non-working pins !!!
    VAR Statements do not work with ADCIN ( I just wrote a post about some days ago ... shame on me !!! )
    http://www.picbasic.co.uk/forum/showthread.php?t=6522
    So, Instead of :
    "analogport VAR PORTA.0
    WRITE in the Ports definitions :
    "analogport0 CON 0 ' Analog port pin RA.0"
    "analogport1 CON 1 ' Analog port pin RA.1"
    and so on ...
    but take care that AN5 is different from ... RA.5 !!!
    Here we are !!!
    Jun 2007
    Default Yes... It Works Now
    Thank you Alain,
    I spent all day trying to figure out how to solve this problem.
    Once again, thank you, merci .... it was a great help
    Johan
  1. Multiple HPWM question
    By Johan in forum mel PIC BASIC Pro
    Last Post: - 17th October 2007, 14:00
  2. ADC question
    By Srigopal007 in forum mel PIC BASIC Pro
    Last Post: - 8th June 2007, 10:52
  3. sound command & music
    By trying in forum mel PIC BASIC Pro
    Last Post: - 26th May 2006, 15:14
  4. HPWM and A to D interaction question 18F252
    By tcbcats in forum mel PIC BASIC Pro
    Last Post: - 10th May 2006, 04:50
  5. 3 HPWM channels
    Last Post: - 4th April 2006, 03:43
