How to add programmer?
Results 1 to 6 of 6
    Sep 2005
    Campbell, CA
    I assume you are using Micro Code Studio as an editor.
    Any programmer the can be used with MCStudio must have a command-line interface, and I don't believe that the ICD2 has that option.
    I use an ICD2 and I simply open MPLAB and IMPORT the .HEX file that PBP produces. You can program your chip that way.
    Charles Linquist
    Hi Charles
    Thanks for the reply. I've been using the MPLAB import procedure up to this point. I was hoping there was a better way. Thanks for trying.
    You can still use PBP within MPLAB if you install the language toolsuite plugin.
    http://www.melabs.com/support/mplab.htm
    But, there's no real advantage over MicroCode Studio
    May 2006
    MI
    I think there might be a better way. Recently purchased an ICD 2 clone
    and set MPLAB to work with PBP. Its take a little work and some careful
    instructions (not to mention it was little hard to find), but give this site
    a try. I think its what your looking for.
    http://www.blueroomelectronics.com/inchworm.htm
    Look towards the bottom of the page there will be link that will
    take you to a site that walks you through the procedure of how
    to make PBP and MPLAB work together (which also let us the ICD2).
    Hope this helps
    May 2006
    MI
    Ahh, better yet, here is the actual link to the step by step
    guide.
    http://melabs.com/support/mplab.htm
    You will use MPLAB but it will acept PBP code. This will let you
    use your ICD2 to program you PIC.
    Good Luck
  1. Studio lost programmer
    By MOUNTAIN747 in forum General
    Last Post: - 10th January 2010, 03:47
  2. Melabs U2 Programmer Command Line Options
    By Robert Wells in forum General
    Last Post: - 3rd July 2009, 03:11
  3. problems with USB programmer
    By malc-c in forum General
    Last Post: - 10th May 2007, 21:14
  4. USB programmer problems
    By uiucee2003 in forum USB
    Last Post: - 16th August 2006, 00:47
  5. General Programmer Questions
    By mslaney in forum General
    Last Post: - 17th December 2004, 19:16
