bisiklet hız ölçer (bicycle speedmetre )
Results 1 to 37 of 37
    Jan 2006
    Istanbul
    Hi zaferakbay,
    Welcome to the forum, and thank you ( Teşekkürler ) for sharing your code.
    I hope the language discussion does not turn you off of this forum, the folks around here really do want to help as you know from reading past post. Some times though we all have bad days.
    It is funny that in your first two post saying thank you to Darrel and Trent for the code they posted no one made a big deal about your language.
    About your project.. What are you using for the speed sensor?
    Let me jump in and do some translation here!
    Hey Zafer kardeşim,
    Okadar tartışmadan sonra bak zafer bizim oldu.
    Nası ama?
    Sen yolla kardeşim sorularını yada ne istersen Türkçe.
    Şimdi bu vatandaş, sensör olarak ne kullandığını soruyor. Hani sana yağcılık olsun diye. Yoksa onun için çok önemli değil ama yinede sıcak bir yaklaşım. Aferim ona.
    Edit: That is an affirmative and proactive approach Dave !
    Mar 2006
    Ankara -Turkey
    Default İşte bukadar...
    biri yazmışsa başka biride tercüme eder okadar!.....
    Birbirimize yardım için buradayız.
    We are here to help each other....
    Quote Originally Posted by turkuaz View Post
    Could someone translate?
    Jan 2006
    Istanbul
    Sure!
    turkuaz says that "if someone wrote in one language then some other will translate". AND he says "that's it".
    Quote Originally Posted by sayzer View Post
    Sure!
    Easy as that. And if someone were to say something that they should not as Melanie was concerned about, the translator could then let a moderator know.
    No problems if you do not get tired of translating
    Talking Babel tower on tracks ...
    Mhhhh,
    for the answer ... how many languages officially to translate into ???
    try being serious ... for once !!!
    You take all of the fun out of it.
    But I do not see a problem if someone is having problems with English. Just do not think that should be a reason not to help them learn. If there is someone that will translate "OK". They will get it sooner or later.
    Maybe that comes from living on the border.
