Individual pic ID
Results 1 to 7 of 7
    New Zealand
    Default Individual pic ID
    I'm building some remote control devices and would like a control from one device to not interfere with another - so would like an individual ID to go along with it's transmission. I think I'll be ok with sorting out the receiver learning side of it, just not sure how to program the remotes all with individual ID codes apart from doing it manually - I'm not really that fond of that idea tho! - call me lazy!
    They don't have to have a very high level of security 1 byte would be plenty. Any idea on how I can set the ID into the eeprom on programming? I'm using Microcode Studio and a MicroPro programmer (DIY K128) - (BTW I think a very good programmer)
    mmm... assuming your EEPROM is blank at it's first power-up. You may use a spare i/o and dump a Serial number in? If there's no SerialNumber in the EEPROM, the whole thing just don't work... Still possible to enter it manually when you burn your PIC. All my PIC Programmer software allow that.
    If your PIC have it and your Device Programmer allow automatic ID serialisation, you could still use the PIC ID?
    New Zealand
    Just had a thought - do you think I could just use a counter in a loop and however long it takes you to press the button on first powerup sets the ID?
    Yeah but... how will you know the results?
    Still possible yo use an ADC pin and a trim pot for less fancy solution.
    Dip switches as well.
    New Zealand
    I was thinking, the transmitter sent out a standard identifier, then it's own ID, then the function. Then I could on first powerup make the transmitter look for standard identifier, then set itself for the first ID that it sees, maybe allow a couple of codes to be set - even just do the search on a jumper connect or something. - I'm inventing as I go here
    Mentor, Ohio
    Smile
    Hi George,
    Did you search this forum for Mister E's PIC Network. This should give you a good start on what it is you are looking at doing.
    BobK
    Quote Originally Posted by George View Post
    As Steve suggested first check if your programmer supports Serialization. If it does then it is already done.
    If not, then why not put in a special place (program area or eeprom area) the byte you want every time you program the chip. Of course a different one every time!
  1. SMS via pic
    By kenandere in forum GSM
    Last Post: - 10th March 2010, 10:00
  2. Replies: 67
    Last Post: - 8th December 2009, 02:27
  3. HSERIN & Interupts (aka controlling PIC programs from a remote PC)
    Last Post: - 17th June 2009, 14:46
  4. pic to pic ir link versus wired link : help please anyone
    Last Post: - 30th May 2008, 21:01
