PIC to PIC communication problem
Results 1 to 3 of 3
Threaded View
    Mar 2006
    INDIA
    Default PIC to PIC communication problem
    this code is for length measurements with encoder. Main aim is to count pulse from encoder and Synchronously shift out counter Var on ClockPin and Data Pin to another PIC.
    Problem is, counter section and SHIFOUT is working but SHIFTIN on another PIC not working.
    @Config = _XT_OSC & _WDT_OFF & _PWRTE_OFF & _LVP_OFF & _BODEN_OFF
    Define PIC16F877A
    INCLUDE "MODEDEFS.BAS"
    CMCON = 7
    ADCON1 = 7
    CVRCON = %00000000 'CVref turned off
    TRISA = %11111111
    TRISB = %11111111 ' Portb.0 = Encoder input
    TRISC = %11111111
    TRISD = %11111111
    TRISE = %000
    Symbol HC_latch = PORTE.2 ' pin 10
    symbol HC_Data = PORTE.1 ' pin 9
    SYMBOL HC_Clk = PORTE.0 ' pin 8
    Dummy VAR WORD
    pitch var word
    pitch = 62206
    W1 var word
    B1 VAR BYTE
    B2 VAR BYTE
    B3 VAR BYTE
    B4 VAR BYTE
    B5 VAR BYTE
    W0 VAR WORD
    DIGIT1 VAR BYTE
    DIGIT2 VAR BYTE
    DIGIT3 VAR BYTE
    DIGIT4 VAR BYTE
    DIGIT5 VAR BYTE
    DIGIT6 VAR BYTE
    MASK VAR BYTE
    B1 = 0
    B2 = 0
    B3 = 0
    B4 = 0
    B5 = 0
    W0 = 0
    E1 VAR BYTE
    E2 VAR BYTE
    E3 VAR BYTE
    E4 VAR BYTE
    E5 VAR BYTE
    PAUSE 500
    OPTION_REG = %00000000
    On Interrupt Goto myint
    INTCON = $90
    LOOP: IF PORTA.0 = 1 THEN W0 = 0 'Reset Counter
    dummy = pitch * W0
    w1 = div32 1000
    w1 = w1/10
    w1 = w1/6
    B1 = W1 DIG 0
    B2 = W1 DIG 1
    B3 = W1 DIG 2
    B4 = W1 DIG 3
    B5 = W1 DIG 4
    DIGIT1 = B1
    LOOKUP DIGIT1,[$C0,$F9,$A4,$B0,$99,$92,$82,$F8,$80,$90],MASK
    E1 = MASK
    DIGIT2 = B2
    LOOKUP DIGIT2,[$C0,$F9,$A4,$B0,$99,$92,$82,$F8,$80,$90],MASK
    E2 = MASK
    DIGIT3 = B3
    LOOKUP DIGIT3,[$C0,$F9,$A4,$B0,$99,$92,$82,$F8,$80,$90],MASK
    E3 = MASK
    DIGIT4 = B4
    LOOKUP DIGIT4,[$C0,$F9,$A4,$B0,$99,$92,$82,$F8,$80,$90],MASK
    E4 = MASK
    DIGIT5 = B5
    LOOKUP DIGIT5,[$C0,$F9,$A4,$B0,$99,$92,$82,$F8,$80,$90],MASK
    E5 = MASK
    HC_Latch=0
    shiftout HC_data, HC_Clk, MSBFIRST,[E1,E2,E3,E4,E5,$ff]
    pauseus 1
    HC_Latch=1
    GOTO LOOP
    Disable
    myint:
    W0 = W0 +1
    INTCON.1 = 0
    resume
    Enable
    __________________________________________________ ______________
    Recive data on another chip
    Define PIC16F877A
    INCLUDE "MYLCD.BAS"
    CMCON = 7
    ADCON1 = 7
    TRISA = %11111111
    TRISB = %11111111
    TRISC = %11111111
    TRISD = %11111111
    TRISE = %111
    E1 VAR BYTE
    E2 VAR BYTE
    E3 VAR BYTE
    E4 VAR BYTE
    E5 VAR BYTE
    main: HC_Latch=0
    shiftin HC_data, HC_Clk, MSBFIRST,[E1,E2,E3,E4,E5,$ff]
    pauseus 1
    HC_Latch=1
    lcdout $fe,1
    lcdout E5,E4,E3,E2,E1
  1. 5v for PIC problem
    By financecatalyst in forum Schematics
    Last Post: - 24th August 2009, 17:04
  2. help for serial communication pic to pic
    By jasem700 in forum Serial
    Last Post: - 27th February 2009, 17:06
  3. serial communication between CMUcam and PIC 16F877
    By gengkeys in forum mel PIC BASIC Pro
    Last Post: - 30th March 2007, 07:43
  4. PIC 2 PIC communication
    By Mario in forum Forum Requests
    Last Post: - 28th April 2006, 02:56
  5. PIC problem, ways to do reset
    By lab310 in forum mel PIC BASIC Pro
    Last Post: - 26th May 2005, 15:31
