Is there a better way...
Results 1 to 9 of 9
    Dec 2005
    Default Is there a better way...
    I have a device that is completely controlled via RS-232. The commands to make the PIC do something, like read ADC, change levels of output pins, read SPI devices, etc. is all controlled by 3 letter commands from a PC. I use the HW uart on the PIC chip to load the data into a circular buffer and then look for a cr as a terminator. Then in my code I used multiple IF/THEN lines to match a valid command and then a subroutine to perform the action. The part that bothers me is the multiple IF/THEN about 20 of them that look like this:
    IF chrbuf(0)="R" AND chrbuf(1)="T" AND chrbuf(2)="F" THEN GOSUB xxxxx
    Is there a better or cleaner way to decode the three letter commands than using long multiple IF/THEN statements?
    Terry
    How about a checksum of the first 3 characters and a select case with the checksum?
    Not sure about the checksum.
    Wouldn't RTF and FRT end up the with the same number?
    It depends on the letter combinations you need, but if there are common letters between the commands, maybe ...
    <font color="#000000"><b>IF </b>chrbuf(0)=<font color="#FF0000">&quot;R&quot; </font><b>THEN
        IF </b>chrbuf(1)=<font color="#FF0000">&quot;T&quot; </font><b>THEN
            IF </b>chrbuf(2)=<font color="#FF0000">&quot;F&quot; </font><b>THEN GOSUB </b>RTF
            <b>IF </b>chrbuf(2)=<font color="#FF0000">&quot;M&quot; </font><b>THEN GOSUB </b>RTM
            <b>IF </b>chrbuf(2)=<font color="#FF0000">&quot;R&quot; </font><b>THEN GOSUB </b>RTR
        <b>ELSE
            IF </b>chrbuf(1)=<font color="#FF0000">&quot;Q&quot; </font><b>THEN
                IF </b>chrbuf(2)=<font color="#FF0000">&quot;P&quot; </font><b>THEN GOSUB </b>RQP
                <b>IF </b>chrbuf(2)=<font color="#FF0000">&quot;C&quot; </font><b>THEN GOSUB </b>RQC
                <b>IF </b>chrbuf(2)=<font color="#FF0000">&quot;A&quot; </font><b>THEN GOSUB </b>RQA
            <b>ENDIF
        IF </b>chrbuf(0)=<font color="#FF0000">&quot;T&quot; </font><b>THEN
                IF </b>chrbuf(2)=<font color="#FF0000">&quot;F&quot; </font><b>THEN GOSUB </b>TTF
                <b>IF </b>chrbuf(2)=<font color="#FF0000">&quot;M&quot; </font><b>THEN GOSUB </b>TTM
                <b>IF </b>chrbuf(2)=<font color="#FF0000">&quot;R&quot; </font><b>THEN GOSUB </b>TTR
            <b>ENDIF
                IF </b>chrbuf(2)=<font color="#FF0000">&quot;Z&quot; </font><b>THEN GOSUB </b>TQZ
                <b>IF </b>chrbuf(2)=<font color="#FF0000">&quot;S&quot; </font><b>THEN GOSUB </b>TQS
                <b>IF </b>chrbuf(2)=<font color="#FF0000">&quot;1&quot; </font><b>THEN GOSUB </b>TQ1
            <b>ENDIF
    </b>
    Dec 2005
    Thanks for the ideas, it seems like PBP really needs some string capability where then the "case" statement could be used which I think would then be a natural for this type of application.
    Terry
    There are lots of different ways... not nescessarilly better, just different...
    Take a look at this example posted OMG!!! Three years ago!!!
    http://www.picbasic.co.uk/forum/showthread.php?t=573
    It does pretty much what you're doing, receiving a command string terminated by a CR, then parsing that string for embedded commands to act upon... just another angle on the same theme...
    So, as another example, if all your commands are say 3 characters long each, then stick them all together into your program as a long string (who says you can't build strings with PICBasic!!!) with a separator character between them (you can have that "string" in EEPROM, or within your program code)... eg...
    iRobotActions:
    	db	0x00,"HUG"		; Greeting
    	db	0x00,"EAT"		; Recharge Batteries
    	db	0x00,"FLY"		; Go Somewhere
    	db	0x00,"KIL"		; Prime Directive
    	db	0x00,"RTM"		; Learn
    	db	0x00,"SEX"		; Have Fun
    	db	0x00,"DIE"		; Wait for armageddon
    ...then simply scan that "string" to find the position of the command you seek (which in turn will give you a number based on the position of that command within the string). Then armed with that number you can then simply use your case statement (or even a bunch of simple IF's). This basically gives you unlimited scope for your embedded commands.
    nb. You need a separator between the commands, otherwise a random jumble like 'EXD' as the last two characters of 'SEX' and the first of 'DIE' would return a result.
    iRobotActions:
    Could you please help with how to search this string to get the location number?
    Many Thanks
    db?? nah... grandma tricks, there's a better way, use the following...
    http://www.pbpgroup.com/modules/wfse...p?articleid=10
    db?? nah... grandma tricks...
    Hmm, from the avatar I don't think Melanie is so much old grandma...!
    yeah i know... just kidding a little bit
    I figure the 'Embedded Strings in code space' stuff will be somehow easy to implement, and will eat less code space.
