Do it in stages and learn along the way...
The program text explained that you can't do anything that takes more than about 10mS... so...
rather than this...
If you simply did this...Code:MAIN: if Update = 1 then update = 0 if second = 0 and minute = 9 and hour = 0 then goto beep1 if second = 0 and minute = 27 and hour = 0 then goto beep1 endif BEEP1: sound buzzer,[100,10,50,10] goto main
Then for one whole minute at those two designated Hours and Minutes the Buzzer pin will go high. This assumes you put Buzzer=0 somewhere at the very start of the program when it first comes alive and initialises.Code:Main: if (minute=9 and hour=0) then Buzzer=1 else if (minute=27 and hour=0) then Buzzer=1 else Buzzer=0 endif endif
Check if this works for you FIRST...
Then you can work out how you can move on from there and make the pin modulate something in the available time slot to drive a sounder...
