To each their own, but I have better luck modifying the *.inc file for the configs.
One thing I do not see is "DEFINE OSC 4" at the top of your code. If it is there then this is a good reason to use the CODE brackets and post your whole code.
Try thisWhen you have a problem like this go basic.. no variables, one piece of hardware and so on.Code:DEFINE OSC 4 ANSEL=%00000000 CMCON=7 LOOP: HIGH GPIO.2 PAUSE 100 LOW GPIO.2 PAUSE 100 GOTO LOOP
This is my 12F675.inc set up
Are you using PM or MPASM?Code:NOLIST ifdef PM_USED LIST include 'M12F675.INC' ; PM header device pic12F675, intrc_osc, wdt_on, pwrt_on, mclr_on, protect_off XALL NOLIST else LIST LIST p = 12F675, r = dec, w = -302 INCLUDE "P12F675.INC" ; MPASM Header __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_ON & _MCLRE_OFF & _CP_OFF NOLIST endif LIST
