Target device <> Selected Device????
Results 1 to 6 of 6
    Cool Target device <> Selected Device????
    Hi, Forgive me for my question as it may seem stupid.
    I am a database programmer so I know nothing about this software but I am working on something where I need to program a Pic18F242 Microcontroller.
    I purchased the melabs serial programmer with the Zip 28/40 pin adapter.
    I am using Pic Basic Pro to write my program that will be programmed into controller.
    Anyhow, I have my serial programmer hooked up to the AC Adapter, a serial to USB cable (i dont have serial port on computer) and the ZIP adapter plugged into the serial programmer and my microcontroller plugged into the zif adapter in the pin placement that is required per their documentation (pin 1 next to zif adapter lever).
    When I go to get target information or program the controller I get an error that says target device does not match selected device. I have set my selected device in the melabs serial programming software to PIC18F2420. the software says my device id is FFFF and does not match selected device id.
    Does anyone have any suggestions on what i am doing wrong? I am lost as to the next step i need to take to proceed.
    Thanks a lot guys/gals, beers on me!
    deep
    Mentor, Ohio
    Smile
    Hello Deepgfishing,
    Welcome to PBP! I might be wrong here but if memory serves me right you can't use a USB to serial adaptor with MELabs serial programmers. I went thru this last year and was told there's something in the timing that interfers with the proper operation. MELabs does have a fine USB programmer that will work with the adaptors you bought.
    BobK
    Jul 2005
    Midwest
    you start off saying that you are using a 18F242 but then mention your programming software is set for a 18F2420. Is this just a typo?
    good luck
    If it's a typo mistake, then just disable the DeviceID check.. it's not useful anyway... well it may have some advantages, but as long as you're sure that the selected device is the same as in the ZIFF...
    Smile
    Quote Originally Posted by Steve_88 View Post
    good luck
    Hey guys thanks for all the replies. First off I guess I will call meLabs and see if the serial to USB adapter will work with this programmer.
    Yes, that was a typo sorry guys. Would it be okay if I shared the very simple (10 lines or so) program I wrote and see if you guys think it will work.
    deepgfishing
    deepgfishing, Contact me thru PM.......
  1. Watchdog Timers
    Last Post: - 27th August 2014, 18:03
  2. ICDWarn0020: Invalid target device id
    By pravec065 in forum General
    Last Post: - 4th August 2008, 13:43
  3. Replies: 8
    Last Post: - 24th April 2008, 22:19
  4. Target device does not match
    By krohtech in forum mel PIC BASIC Pro
    Last Post: - 2nd February 2008, 04:20
  5. PIC18F4620 not Target Device
    By kiwipiper in forum mel PIC BASIC Pro
    Last Post: - 17th October 2007, 19:42
