no text on LCD
Results 1 to 31 of 31
Thread: no text on LCD
    Jun 2007
    cheers malcom, thats now worked, downloaded the hex on to my PIC.
    But still having problems, only showing line 1 and 3 full of solid blocks.
    My .ASM will work... but Melanie's Example is setuped for a 2 LINES LCD
    so just change the following
    	Define LCD_LINES 2			' Using 2 line Display
    to
    	Define LCD_LINES 4			' Using 4 line Display
    OR use the corrected .HEX in attachment
    Jun 2007
    cheers mister e, just found out it was a problem with my code as i am fairly new to it, but i went over my circuit with a fine tooth comb, litteraly,
    using a magnifying glass i was able to just make out a solder bridge between pin 6 and the data lines next to it which are grounded, therefore was not getting a signal. this will have only happend after i grounded them as mel said in an earlier post, as they had not been toutched previousley.
    cheers every one for your help and for putting up with me.
    dont worry i aint running away, ill be back soon to annoy every one again, haha
    does any one know any sites with information on so i can learn how to program more in that language?
    thanx
    malc-c's Avatar
    malc-c Guest
    Glad to hear you resolved the issue.
    When you say that language do you mean PicBASIC pro like
    High BlinkyLED				' Set LED pin High
    	Pause 1000				' Wait one Second
    	LCDOUT "Hello Dj tempo"			' Write message
    	Low BlinkyLED				' Set LED pin Low
    or do you mean Assembly code like
    RRF	Send_bit, F
    	BTFSC	STATUS, C		; Test Carry if 1 then set output
    	BSF	OUTPUT
    	BTFSS	STATUS, C		; Test Carry if 0 then clear output
    	BCF	OUTPUT
    	BSF	Send_Count, 6
    	GOTO	Del_232
    If its PicBASIC have a look at http://www.crownhill.co.uk/product.php?prod=17
    http://www.mecanique.co.uk/products/compiler/pbp.html
    or for examples and more reference
    http://www.rentron.com/PicBasic/prod...CBASIC-PRO.htm
    Hope that helps
    Jun 2007
    cheers m8,
    i like the look of Pic bsic more as i find it easier to understand, so will be continuing in this language.
  1. Replies: 2
    Last Post: - 5th November 2009, 18:07
    Last Post: - 8th August 2009, 20:54
  3. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  4. LCD issue with EasyPIC5
    By manwolf in forum mel PIC BASIC Pro
    Last Post: - 15th June 2008, 10:17
  5. LCD will not start
