It is not really clear to me what your actual problem is and what you are trying to achieve.
Anyway there is one thing I would like to mention:
If you like to use HSEROUT to communicate with a PC you MUST use a level shifert/inverter.
With HSEROUT you can't toggle the mode (TRUE/INVERTED)
The serial communication and mode issue has been discussed many times on this forum.
(try a "search")
If you would let us know what your hardware setup looks like and what you are trying to achieve we will certainly be able to help.
