I use Pic F877 on my project. ı count rotaion of electrical motor rpm.But when ı started the motor pic reset it itself. WHY?.Pic and motor plugged same electrical wire .
How can ı solve this stuation.
Thanks everyone who help me.
Could be tons of things, can you post your schematic?
Isn't that what he said? He's got both on the same power supply!
BobK
Yes .You are right. I use RA4 for counting.Is that wrong pin?
I use regulated supply for Pic(5V DC) and motor is connected to same plug (on the wall) but not driven energy from regulated supply that pic use.
some time everything goes good but sometimes occurs this problem.
I use relay to run motor.Pic drive raley than motor running.Motor uses 220Volt AC not pic supply
