Error code [112]/[113]
Results 1 to 4 of 4
Threaded View
    Jun 2007
    Default Error code [112]/[113]
    hi im new to both this site and PIC micro controllers.
    i like to learn the program and solve things myself, but im at the point of nearly pulling my hair out. i require some help.
    i have compiled a new program to interface a PIC16F84A with a 4x20 LCD display.
    i have 2 error codes left showing in the programe using notepad:
    Error[113] : Symbol not previously defined (MOVLW)
    Error[112] : Missing operator
    how do i fix these errors?
    some of error code as follows:
    MPASM 5.01 LCD CODE 4 BIT (2).TXT 6-15-2007 19:06:30 PAGE 1
    LOC OBJECT CODE LINE SOURCE TEXT
    VALUE
    00001 ;ANHEAD84.ASM Header for the alpha neumeric display using 6 I/O
    00002
    Warning[207]: Found label after column 1. (TMR0)
    00000001 00003 TMR0 EQU 1 ;TMR0 is FILE 1
    Warning[207]: Found label after column 1. (PORTA)
    00000005 00004 PORTA EQU 5 ;PORTA is FILE 5
    Warning[207]: Found label after column 1. (PORTB)
    00000006 00005 PORTB EQU 6 ;PORTB is FILE 6
    Warning[207]: Found label after column 1. (STATUS)
    00000003 00006 STATUS EQU 3 ;STATUS is FILE 3
    Warning[207]: Found label after column 1. (ZEROBIT)
    00000002 00007 ZEROBIT EQU 2 ;ZEROBIT is Bit 2
    00008
    00009 LIST P=16F84 ;We are using the 16F84
    0000 00010 ORG 0 ;0 is the start of the address
    0000 2972 00011 GOTO START ;goto start
    00012
    00013 ;SUBROUTINE SECTION.
    00014
    00015 ;3 SECOND DELAY
    0001 0181 00016 DELAY3 CLRF TMR0 ;Start TMR0
    0002 0801 00017 LOOPA MOVF TMR0,W ;Read TMR0 into W
    0003 3C60 00018 SUBLW .96 ;TIME - W
    0004 1D03 00019 BTFSS STATUS,ZEROBIT ;Check TIME-W=0
    0005 2802 00020 GOTO LOOPA
    0006 3400 00021 RETLW 0 ;Return after TMR0 = 96
    00022
    00023 ;P1 SECOND DELAY
    0007 0181 00024 DELAYP1 CLRF TMR0 ;Start TMR0
    0008 0801 00025 LOOPC MOVF TMR0,W ;Read TMR0 into W
    0009 3C03 00026 SUBLW 3 ;TIME - W
    000A 1D03 00027 BTFSS STATUS,ZEROBIT ;Check TIME-W=0
    000B 2808 00028 GOTO LOOPC
    000C 3400 00029 RETLW 0 ;return after TMR0 = 3
    00030
    000D 1505 00031 CLOCK BSF PORTA,2
    000E 0000 00032 NOP
    000F 1105 00033 BCF PORTA,2
    0010 0000 00034 NOP
    0011 3400 00035 RETLW 0
    00036
    0012 3002 00037 A MOVLW 2 ;enables the display
    0013 0085 00038 MOVWF PORTA
    0014 3004 00039 MOVLW 4H
    0015 0086 00040 MOVWF PORTB
    0016 200D 00041 CALL CLOCK
    0017 3001 00042 MOVLW 1H ;41 is code for
    0018 0086 00043 MOVWF PORTB
    0019 200D 00044 CALL CLOCK ;clock character onto display
    001A 3400 00045 RETLW 0
    00046
    Warning[204]: Found pseudo-op in column 1. (B)
    MPASM 5.01 LCD CODE 4 BIT (2).TXT 6-15-2007 19:06:30 PAGE 2
    VALUE
    001B 2800 00047 B MOVLW 2 ;enables the display
    001C 0085 00048 MOVWF PORTA
    001D 3004 00049 MOVLW 4H
    001E 0086 00050 MOVWF PORTB
    001F 200D 00051 CALL CLOCK
    0020 3002 00052 MOVLW 2H ;42 is code for
    0021 0086 00053 MOVWF PORTB
    0022 200D 00054 CALL CLOCK ;clock character onto display
    0023 3400 00055 RETLW 0
    00056
    0024 3002 00057 C MOVLW 2 ;enables the display
    0025 0085 00058 MOVWF PORTA
    0026 3004 00059 MOVLW 4H
    0027 0086 00060 MOVWF PORTB
    0028 200D 00061 CALL CLOCK
    0029 3003 00062 MOVLW 3H ;43 is code for
    002A 0086 00063 MOVWF PORTB
    002B 200D 00064 CALL CLOCK ;clock character onto display
    002C 3400 00065 RETLW 0
    any help much apreciated.
