counter for counting magnetic microswich press
Results 1 to 5 of 5
    Mar 2006
    Ankara -Turkey
    Default counter for counting magnetic microswich press
    Hi Everyone.
    I want to count microswich open-close positon to count disk rotation.
    ı have a micro magnetic swich which is produce 2 signal when maghnetic disc rotating 1 time.magnetic swich debounce time is 20 uSec.
    I use Pic16F877
    This is my code:
    ..PORTA.4 input pin...
    loopHy:
    IF PORTA.4 = 0 THEN loopHy
    count = count+50
    Lcdout $fe, $C0, #count:Pause 250(debounce time for slow rotation)
    goto loopHy
    is it Ok .or anybody give me advise.
    Thanks.
    Mar 2006
    Ankara -Turkey
    Quote Originally Posted by turkuaz View Post
    Hi Everyone.
    I use Pic16F877
    This is my code:
    loopHy:
    count = count+1
    goto loopHy
    Thanks.
    I solve this problem myself as follows:
    loopHy:
    count = count+1
    While portA.4=1 Then
    Wend
    goto loopHy
    It is working nice
    thanks everyone.
    Carefull when you use reserved word... COUNT is also a PBP statement. You should change it to something else
    Now JUST FOR FUN, and as your current hardware is setuped to use it, try this one which use TMR0
            ADCON1 = 7
            pCount    VAR BYTE
            OldpCount VAR BYTE
            CLEAR
            TMR0 = 0
            OLDPCOUNT = 1
    Start:
            pCount = TMR0
            IF pCount != OldpCount then
                LCDOUT $FE,$C0, #pCount
                OldpCount = pCount
            GOTO Start
    Mar 2006
    Ankara -Turkey
            ADCON1 = 7
            pCount    VAR BYTE
            OldpCount VAR BYTE
            CLEAR
            TMR0 = 0
            OLDPCOUNT = 1
    Start:
            pCount = TMR0
                OldpCount = pCount
            GOTO Start
    Thanks for your advice.
    I chanced count to sayim(in Turkish)
    I do not want to use timer because when disk begin to rotation ( which is slow rotation)micro magnet take to time to pass under the magnetic swich so swich is on position and count is going to count I do not this. I want only one time not elong with passing is going on.
    Question Some more info, please
    Hi Turkuaz,
    Could you tell us what's your MAX RPM ( or half freq ...) counting rate expected ???
    Will help for a solution.
    I think we could detect only the Low-to-High ( or High-to-Low ) transitions, to get rid of the rotation speed span.
    But the debouncing time must fit the max RPM !!!
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 07:14
  2. 20 Digit Virtual LED Counter
    Last Post: - 19th November 2007, 06:02
  3. Replies: 14
    Last Post: - 26th September 2007, 06:41
  4. How to set TMRO & TMR3 as Counter?.
    By NatureTech in forum mel PIC BASIC Pro
    Last Post: - 18th May 2007, 09:52
  5. Microcontroller with 2 way paging application problem
