Serial coms with a pc
Results 1 to 14 of 14
Threaded View
  1. #6
    i just copy/paste your code and, yes indeed there's few mistake.
    first..
    DEFINE HSER_RCSTA 90h ;Set receive register to receiver enabled
    DEFINE HSER_TXSTA 20h ;Set transmit regester to transmitter enabled
    DEFINE HSER_BAUD 2400 ;Set baud rate
    DEFINE HSER_SPBRG 25 ;Set spbrg regester
    In red, you overwrite PBP calcs. This result of a bad SPBRG setting for a TXSTA=20. Also, as you're using HSERIN, i would suggest you to use HSER_CLROERR feature to clear all possible overflow error. The correct declaration should be
    DEFINE HSER_SPBRG 25  ' 9600 Baud @ 4MHz, 0.16%
    Even with this, you have configure the RX pin as output so change TRISB to
    TRISB = %00000010 ' RB1(RX) as input, others to Output
    that sort few error, but unless you want to have a full-filled of "Value of I:" screen, i'll suggest you to remove the timeout delay and it's jump label
    HSERIN [i]
    This way, the program will sit there and wait for a user entry.
    EVEN with the above correction done, you may have some problem if you're using the internal OSC, if your "Value of I" message is messy, use an external one OR try with a lower baudrate. Here, it doesn't work @9600 baud with the internal OSC. The output looks like
    VX• ˁ'‘
    i don't know for others... but i can't understand what the above ask me
    the full corrected code, with config fuse setting for MPASM and a external 4MHz crystal, but without the ANSI feature looks like
        ;INCLUDE "ANSI.INC"
        @ __CONFIG _XT_OSC  & _MCLRE_ON  &  _LVP_OFF & _WDT_OFF & _PWRTE_ON  & _BODEN_ON
        CMCON = %00000111 ;Disable Comparator module's
        OPTION_REG = %11010111 ;Set PIC options
        INTCON = 0 ;Disable interrupts
        TRISA = 255 ;SET PORTA AS INPUTS
        I VAR BYTE
        I = 20
    loop:
        ;@ ClearScr ; Clear Screen
        HSEROUT ["Value of I:",I,10,13]
        HSERIN [I]
        GOTO loop
    More information on config fuse and possible compilation warning messages at the following link
    hth
  1. PIC18F4680 to PC via MAX232 (RS232 serial) no output
    By opticsteam1 in forum mel PIC BASIC Pro
    Last Post: - 14th April 2008, 21:39
  2. interfacing to the pc serial port
    By kelangfei in forum General
    Last Post: - 7th October 2007, 23:35
  3. PC serial port funny
    By nicjo in forum Serial
    Last Post: - 6th February 2007, 06:34
  4. Replies: 2
    Last Post: - 28th April 2006, 13:10
  5. Interrupt and Serial communication to PC.
    By obaskirt in forum mel PIC BASIC
    Last Post: - 17th June 2005, 21:01
