Serial coms with a pc
Results 1 to 14 of 14
    Question Serial coms with a pc
    Hi there
    I have built a circuit with a pic16f627 and a so232acp chip. The idea is to read an input and display it on hyper terminal and toggle two leds if I send a command from the pc, I am using the on board usart.
    The transmitting from the pic work 100% but I can not seem to get it responding to the commands from the pc. Can anyone please help; here is the testing code I use.
    INCLUDE "ANSI.INC"
    CMCON = %00000111 ;Disable Comparator module's
    OPTION_REG = %11010111 ;Set PIC options
    INTCON = 0 ;Disable interrupts
    TRISB = %00000000 ;RB7...RB0 are outputs.
    TRISA = 255 ;SET PORTA AS INPUTS
    DEFINE HSER_RCSTA 90h ;Set receive register to receiver enabled
    DEFINE HSER_TXSTA 20h ;Set transmit regester to transmitter enabled
    DEFINE HSER_BAUD 2400 ;Set baud rate
    DEFINE HSER_SPBRG 25 ;Set spbrg regester
    I VAR BYTE
    I = 0
    PORTB.6 = 1
    loop:
    I =0
    @ ClearScr ; Clear Screen
    HSEROUT ["Value of input 1:",DEC PORTA.0,10,13]
    HSEROUT ["Please select a command",10,13]
    HSEROUT [9,"1 = Flash leds",10,13]
    HSERIN 5000,LOOP,[I]
    IF I = 1 THEN
    PORTB.7 = 1
    PORTB.6 = 0
    PAUSE 1000
    PORTB.7 = 0
    PORTB.6 = 1
    GOTO LOOP
    GOTO LOOP
    Bombay, India
    Try checking for the condition
    If i = "1" then
    since the keypressed from the pc is a printable ascii character.
    Jerson
    INCLUDE  "ANSI.INC"
    cmcon=7:option_reg=$d7:intcon=0:trisb=0:trisa=$ff
    temp var byte:I VAR BYTE:I = 0
    loop:
    I =0
    hserout ["Value of input 1:",dec porta.0,10,13]
    hserout ["Please select a command",10,13]
    hserout [9,"1 = Flash 1 LED",10,13]:hserout [9,"2 = Flash 2 LED",10,13]
    hserout [9,"3 = Flash Both LED",10,13]:hserin 5000,loop,[I]
    IF I = "1" THEN
    for temp = 1 to 10:PORTB.7 = 1:pause 1000:portb.7=0:pause 1000:next temp
    if i = "2" then
    for temp = 1 to 10:portb.6=1:pause 1000:portb.6=0:pause 1000:next temp
    if i="3" then
    for temp = 1 to 10:portb.6=1:portb.7=1:pause 1000:portb.6=0
    GOTO LOOP
    Try that out...
    EDIT: DOH! Jerson beat me to it!
    Thank you for the reply, but stil nothing.
    I am starting to think my hardware is faulty. I have written a program that acording to me could ecco what is sended to the pic. do you agree with the program, if it is correct i definitly need to start looking at my hardware.
    Thank you again for al the help
    INCLUDE "ANSI.INC"
    I VAR BYTE
    I = 20
    loop:
    HSEROUT ["Value of I:",I,10,13]
    GOTO loop
    Loopback with lower case to upper case translation (shows the PIC is actually working and that the PC isn't just receiving the same thing it sent out, i.e. local echo):
    include "modedefs.bas"
    cmcon=7:option_reg=$d7:trisb=0:trisa=$ff:i var byte
    serin portb.1,n2400,I:if (i > 96) and (i < 123) then i = i - 32
    serout portb.2,n2400,[I]:goto main
    And I just noticed something in the code in your last post. Take out the clear screen and if anything happens...
    i just copy/paste your code and, yes indeed there's few mistake.
    first..
    In red, you overwrite PBP calcs. This result of a bad SPBRG setting for a TXSTA=20. Also, as you're using HSERIN, i would suggest you to use HSER_CLROERR feature to clear all possible overflow error. The correct declaration should be
    DEFINE HSER_SPBRG 25  ' 9600 Baud @ 4MHz, 0.16%
    Even with this, you have configure the RX pin as output so change TRISB to
    TRISB = %00000010 ' RB1(RX) as input, others to Output
    that sort few error, but unless you want to have a full-filled of "Value of I:" screen, i'll suggest you to remove the timeout delay and it's jump label
    HSERIN [i]
    This way, the program will sit there and wait for a user entry.
    EVEN with the above correction done, you may have some problem if you're using the internal OSC, if your "Value of I" message is messy, use an external one OR try with a lower baudrate. Here, it doesn't work @9600 baud with the internal OSC. The output looks like
    VX• ˁ'‘
    i don't know for others... but i can't understand what the above ask me
    the full corrected code, with config fuse setting for MPASM and a external 4MHz crystal, but without the ANSI feature looks like
        ;INCLUDE "ANSI.INC"
        @ __CONFIG _XT_OSC  & _MCLRE_ON  &  _LVP_OFF & _WDT_OFF & _PWRTE_ON  & _BODEN_ON
        I VAR BYTE
        I = 20
    loop:
        ;@ ClearScr ; Clear Screen
        HSERIN [I]
        GOTO loop
    More information on config fuse and possible compilation warning messages at the following link
    hth
    Well, I'm always looking for "comments" on my programs.
    I guess "commenting" them out qualifies.
    ANSI.INC
    don't take it personal.. i hate Hyperterminal, sure it has to work with.
    And the best part is ... you don't have to use Hyperterminal.
    Any terminal program that can emulate ANSI will do.
    Even a DOS window with ANSI.SYS loaded. Yuck!
    Deuh... but MisteEZCOM one don't do it
    Anyhow, proof it's working...
    I prefer RealTerm... but... erm, MisterEZCOM is not bad to...
        @ ForColor yellow               ; Set foreground (text) color to yellow
        @ BackColor blue                ; Set background color to blue
    loop:
        HSERIN [i]
        GOTO loop
    Feel better now ?
    Feel better now ?
    Well yes, actually, I do.
    Thank you!
    P.S.
    Where do I get this MisterEZCOM?
    Must have missed that thread.
    It's not released yet, so you didn't missed it
    Thumbs up
    Thank you all
  1. PIC18F4680 to PC via MAX232 (RS232 serial) no output
    By opticsteam1 in forum mel PIC BASIC Pro
    Last Post: - 14th April 2008, 21:39
  2. interfacing to the pc serial port
    By kelangfei in forum General
    Last Post: - 7th October 2007, 23:35
  3. PC serial port funny
    By nicjo in forum Serial
    Last Post: - 6th February 2007, 06:34
  4. Replies: 2
    Last Post: - 28th April 2006, 13:10
  5. Interrupt and Serial communication to PC.
    By obaskirt in forum mel PIC BASIC
    Last Post: - 17th June 2005, 21:01
