Trouble using int. osc. On 18f2455
Results 1 to 8 of 8
    Quote Originally Posted by KPDes View Post
    Yea I checked that, power is getting to the pins and MCLR is pulled high
    No, I meant do you have a .1uf (or similar) capacitor across the power pins?
    And what value resistor do you have pulling MCLR high?
    May 2007
    The pull-up resistor I am using is 6K and I do have a capacitor over the power pins.
    I have gotten it to work by accident when it was programmed for an internal oscillator but the crystal and capacitors were still hooked up from when I was trying an external mode. It started working when I touched one of the capacitors off the crystal, I put it on the scope and the timing was right. It was like the extra capacitance kicked it off or something? Only sometimes this works and it doesn’t work when I set it to external mode. It makes me think it is a configuration problem but I’ve tried everything I can think of
    this could be a breadboard problem. In many occasion it's extra capacitance may screw up things. Higher your crystal value is, worst it is. The trick is to keep every pins short (crystal and capacitors) and be able to mount them directly.
    Here's a setup for a 4MHz crystal
        '   Pic Configuration
        asm
        __CONFIG    _CONFIG1L, _PLLDIV_1_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
                                ;              ;                      ; USB clock source comes from the 96 MHz PLL divided by 2
                                ;              ; [OSC1/OSC2 Src: /1][96 MHz PLL Src: /2]
                                ; No prescale (4 MHz oscillator input drives PLL directly)
        __CONFIG    _CONFIG1H, _FOSC_XTPLL_XT_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
                                ;                  ;               ; Oscillator Switchover mode disabled
                                ;                  ; Fail-Safe Clock Monitor disabled
                                ; XT oscillator, PLL enabled, XT used by USB
        __CONFIG    _CONFIG2L, _PWRT_ON_2L & _BOR_ON_2L  & _BORV_2_2L  & _VREGEN_ON_2L
        __CONFIG    _CONFIG2H, _WDT_OFF_2H
        __CONFIG    _CONFIG3H, _MCLRE_ON_3H & _LPT1OSC_OFF_3H & _PBADEN_OFF_3H & _CCP2MX_ON_3H
        __CONFIG    _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _XINST_OFF_4L & _DEBUG_OFF_4L
        endasm
        DEFINE OSC 48
    Have a look at the USBDemo thread and code, there you'll find some settings.
    http://www.picbasic.co.uk/forum/showthread.php?t=5418
    May 2007
    I am still having trouble.
    I noticed the assembler gives the warning message:
    Warning[217] c:\pbp18f2550.inc 18 : Hex file format specified on command line
    Could this be the problem?
    May 2007
    Problem solved!!
    after many hours of mister_e style head banging , I updated the not just the software (like i did before i made a post) but the firmware on my melabs U2 programmer that fixed the problem
  1. Replies: 4
    Last Post: - 9th October 2009, 09:01
  2. help: TMR0 interrupts disabling PORTAchange interrupts???
    Last Post: - 19th August 2008, 16:10
  3. strange int behaviour
    By tom in forum mel PIC BASIC Pro
    Last Post: - 17th November 2005, 16:41
  4. 18F2525 Int Osc settings?
    Last Post: - 26th March 2005, 23:44
