LN(natural log)
Results 1 to 8 of 8
Thread: LN(natural log)
    actionplus's Avatar
    actionplus Guest
    Default LN(natural log)
    Is there anyway to use natural log in PICBasic Pro. I know that we can use Sin and Cos.
    I am asking to much of PICBasic?
    rpstroj's Avatar
    rpstroj Guest
    There's no way to perform natural log directly. When I had to perform the natural log function on the response from an A/D converter I calculated the natural log function for each A/D 3-bit point in an excel file and put it in a lookup table. Since the lookup table allows 255 entries (3-bits) this worked out.
    If this method won't work you can use linear interpolation. Here's a website about it with many other helpful hints:
    http://www.emesys.com/BS2math3.htm
    actionplus's Avatar
    actionplus Guest
    Default Excel
    I am try to use a 100k thermistor to build a thermometer. And the curve is a relation to a LN formula.
    I guess, I can still calculate each point or so and put it on an excel sheet.
    The problem is that how do I corelate the A/D data from the PIC with a look-up table?
    I have the thermistor connected to a 5V pwr supply and gnd. I get the changes is voltage as the temp differs.
    I guess, I will feed this into A/D port of the PIC16F877 or maybe a 16F628.
    How will I use the data and look-up table to do corelation?
    rpstroj's Avatar
    rpstroj Guest
    I used the look-up table for the exact same application, a thermistor. Here's what I did:
    Use an Excel Spreadsheet to calculate what the tempurature is for each possible A/D count. If you're using 8-bits then that's great because you get 255 entries in the lookup table.
    Use the lookup table with the A/D count as the index. In the actual table insert in order the tempurature entries you calculated in the spreadsheet.
    So your code will look something like this:
    Lookup adcount, [120, 119, 117, 117, ...]
    If that's still not clear I can send you my spreadsheet and code when I did it.
    And if you could help me out with my HSerout problem I'd appreciate it. See my other post.
    actionplus's Avatar
    actionplus Guest
    Default Spreadsheet
    If you could send me spreadsheet, that will be great. If possible the lookup code that relates to that, so I can do the same to mine.
    I have not used the Hserout command yet. I have used the Serout2 and Serin2 though. What is your application? Let me see if I can help you.
    Thanks again
    rpstroj's Avatar
    rpstroj Guest
    INCLUDE "modedefs.bas"               'Contains mode definitions for
    DEFINE OSC 12                   ' Define OSC 12Mhz for HS
    DEFINE ADC_BITS        8
    DEFINE ADC_CLOCK    3
    DEFINE ADC_SAMPLEUS    50
    TRISA = %11111111
    TRISB = %00000000
    ADCON1=3
    'Variables for LCD
    clrSCR CON 12     ' Cntl-L: clear the display.
    posCmd CON 16     ' Position the cursor.
    ESC    CON 27        ' Escape code.
    noCurs CON 4    ' no cursor shown
    Q0 VAR BYTE
    adcount VAR BYTE
    adjust VAR BYTE
    LCD VAR PORTB.0
    Pause 500
          SerOut2 LCD, 16468, [clrSCR]             'Clear LCD and cursor to upper left
    Pause 500
    High PORTB.2
    Loop:
    ADCON0=%11000001
    PauseUs 50
    ADCON0.2 = 1  'start conversion
    PauseUs 50
    adcount=ADRES
          'ADCIN 0, adcount
          adjust=adcount-1
          LookUp adjust,[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1,2,3,4,5,6,6,7,8,9,10,10,11,12,12,13,14,14,15,16,16,17,18,18,19,20,20,21,21,22,22,23,24,24,25,25,26,26,27,27,28,28,29,29,30,30,31,31,32,32,33,33,34,34,35,35,36,36,37,37,37,38,38,39,39,40,40,41,41,41,42,42,43,43,44,44,44,45,45,46,46,47,47,47,48,48,49,49,50,50,50,51,51,52,52,52,53,53,54,54,55,55,55,56,56,57,57,57,58,58,59,59,60,60,60,61,61,62,62,63,63,63,64,64,65,65,66,66,67,67,67,68,68,69,69,70,70,71,71,72,72,73,73,73,74,74,75,75,76,76,77,77,78,78,79,80,80,81,81,82,82,83,83,84,85,85,86,86,87,88,88,89,90,90,91,92,92,93,94,94,95,96,97,97,98,99,100,101,102,102,103,104,105,106,107,108,109,110,112,113,114,115,117,118,120,121,123,125,126,128,130,133,135,138,141,144,147,152,157,163,170,181,200,200],Q0
          SerOut2 LCD, 16468, [posCmd, 87, DEC Q0, " C"]
          SerOut2 LCD, 16468, [posCmd, 107, DEC adcount, " adcount"]
    IF PORTB.2=1 AND Q0>100 Then
        Low PORTB.2
    EndIF
    IF PORTB.2=0 AND Q0<50 Then
        High PORTB.2
    EndIF
    GoTo Loop
    It won't let me upload the spreadsheet.
    Last edited by ScaleRobotics; - 3rd February 2011 at 12:11. Reason: added code tags
    rpstroj's Avatar
    rpstroj Guest
    Here's the spreadsheet. I just changed the extension to .txt so I could upload it. Before you open it change the extension from .txt to .xls then open it with Microsoft Excel. this isn't the exact same one that I used for the program you see, but it's the same idea. Let me know if you have any more questions.
    anj's Avatar
    anj Guest
    I rewrote the "by calc" section from the following site
    into a subroutine and ended up with the following
    Result is the log value multiplied by 1000
    Accuracy should be good enough for what you are doing.
    If you want to know HOW it works, you need to read the text, i just rewrote it and it worked so i was happy.
    LogNo  VAR WORD     ' Number to get log of
    k      VAR byte     'loop var
    X      Var WORD     'temp for processing
    X1     var word     'temp for squaring
    LgX    var word     'lg ( base 2 ) of y the mantissa
    cc     var byte     'characteristic of log
    Lg     var word     'log base 2
    Log    var word     'log base 10
    Ln     var word     'log base e
    etc
    etc
    Logno = varX  'ie no to get result
    gosub getlog
    ' now ref to Lg, Ln or Log as reqd
    GetLog:
      cc = NCD LogNo - 1
      X = LogNo << ( 15 - cc )
      LgX = 0
      for k = 14 to 0 step -1
        X1 = X**X
        if X1.bit15 then
          lgx = lgx | ( dcd k )   'set the bit
          X = X1
          X = ( X1 << 1 ) + 1    'shift er over
      next k
      lg  = cc*1000 + ( lgx**20000/10 )
      log = ( lg ** 19728 )
      ln  = ( lg ** 45426 )
    Andrew
    Last edited by ScaleRobotics; - 3rd February 2011 at 12:09. Reason: added code tags
  1. Gps/glcd
    By karenhornby in forum mel PIC BASIC Pro
    Last Post: - 1st April 2008, 17:18
  2. math operator LOG
    By Eyal in forum mel PIC BASIC Pro
    Last Post: - 23rd July 2004, 00:45
  3. Log and exponential
    By anj in forum mel PIC BASIC Pro
    Last Post: - 5th March 2004, 21:03
