Frequency Counter
Results 1 to 16 of 16
    Jun 2007
    Merango, IL
    To Skimask:
    I tried out the code you gave me and it did write through the EEPROM like it was suppose to. I re-wrote the code I had and it gives me 00 00 when I do not move any of the inputs around at all if I pull the Pulse Wire in and out of ground it seems to give me random values not how many time I pull it in and out, it does seem kind of close though. The code is posted below if you see a problem with it. Thanks for your help btw. I've been working on this all day now and can't seem to get any repeatability.
    @ DEVICE PIC12F683, INTRC_OSC_NOCLKOUT
    @ DEVICE PIC12F683, WDT_ON
    @ DEVICE PIC12F683, PWRT_ON
    @ DEVICE PIC12F683, MCLR_OFF
    @ DEVICE PIC12F683, BOD_ON
    @ DEVICE PIC12F683, CPD_OFF
    @ DEVICE PIC12F683, PROTECT_OFF
    TRISIO = %11111111
    Location var WORD
    Mult_Count VAR BYTE
    Was_Low VAR BIT
    Pulse var gpio.3
    Direction VAR gpio.5
    Mult_Count = 0
    Location = 0
    Was_Low = 0
    PAUSE 500
    IF Pulse = 1 AND Was_Low = 0 THEN
    IF Direction = 1 THEN
    Mult_Count = Mult_Count + 1
    Mult_Count = Mult_Count - 1
    Was_Low = 1
    IF Pulse = 0 THEN
    Was_Low = 0
    IF Mult_Count = 10 THEN
    Location = Location + 1
    Mult_Count = 0
    IF Mult_Count = -10 THEN
    Location = Location - 1
    Mult_Count = 0
    WRITE 0, Location.Byte1
    WRITE 1, Location.Byte0
    GOTO main
    To mister_e:
    I can easily change the clock to 8MHz, I should have done that in the first place. The PWM signal I have done as well, using C code on this chip, and it works pretty nicely. I haven't used the timers before though, although I would really like to go this route with this. My only concern would be I need to be able to count up and down and I'm unsure if can I do so with these Timers. Maybe one way to do so would be to call a interrupt when a direction change is seen and save the timer value before resetting it to 0. Then do the math to another variable with the true position value. I'm gonna start reading on it while I'm still at work. Thanks for the idea it sounds like the best way to go. If you have any advice for going about it let me know. Thanks again.
    Anthony
    See if this helps;
    CMCON0 = 7
    ANSEL = 0
    Comparators & A/D are enabled by default on power-up. To use some pins for
    digital I/O, you need to disable these.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Quote Originally Posted by Asmith View Post
    To Skimask:
    Anthony
    It might be working and counting multiple switch closures due to bouncing switch contacts (noise).
    Mult_Count = 0
    Are you sure that PBP can do negatives???
    Jun 2007
    Merango, IL
    Bruce:
    Thank you I did forget to set up those two registers. I will fix that.
    Joe:
    I'm using a function generator on the input with a scope on it as well and there is no bouncing on the pin. In the end it will be from a hall effect switch which also should not have any bouncing.
    Ioannis:
    I believe PBP will do negative numbers, Location should never be a negative number anyways as 0 would be the lowest number of counts you can have it will be zero we it is set up.
    I think I'm going to try and use the internal timer which I haven't been able to work on it much as work has me burried. I did have some time to write out some code. I will post is below, if you guys would like to comment on it I would appreciate it. It might be a little chopy at the moment though.
    '* Hardware Setups *
    INTCON = %10001000
    PIE1 = %00000000
    PIR1 = %00000000
    OSCCON = %01110000
    '* I/O Pin Descriptions Below *
    '* PIN 1 - VDD - 5V *
    '* PIN 2 - T1CK1 - Input - Pulses from Hall Effect *
    '* PIN 3 -
    '* PIN 4 - GP3 - Input for the direction of the Hall Effect *
    '* PIN 5 - CCP1 - PWM Output to the Analog converter *
    '* PIN 6 -
    '* PIN 7 -
    '* PIN 8 - VSS - Ground *
    TRISIO = %00101000
    WPU = %00000000
    IOC = %00001000
    '* Timer Setup *
    T1CON = %00100111
    Location var WORD
    Mult_Count VAR BYTE
    Was_Low VAR BIT
    Pulse var gpio.3
    Mult_Count = 0
    Location = 0
    Was_Low = 0
    PAUSE 500
    GOTO main
    Ioannis:
    Sure, PBP and assembly both will do negative numbers, but they won't show up the way you want them to...i.e.:
    5 - 6 = -1, but PBP will show 255 (for a byte variable), 65535 (for a word variable).
    You're going to want to add something like this to your program in post #4:
    if mult_count > 0 then mult_count = mult_count - 1
    Was_Low = 1
    IF Mult_Count = -10 THEN(statement won't work the way you want it to in PBP)
    Mult_Count = 0
    Bruce:
    Joe:
    It was worth checking.
    JS
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 06:14
  2. Audio Frequency Counter
    By mister_e in forum Code Examples
    Last Post: - 29th July 2009, 08:25
  3. frequency counter help and pointers
    By comwarrior in forum General
    Last Post: - 30th June 2009, 11:51
  5. Frequency Counter using PIC and PicBasic
    By PICtron in forum mel PIC BASIC Pro
    Last Post: - 28th January 2005, 06:20
