Hi Shortbus,
You might try using a timer to count for you.
Look at this thread: http://www.picbasic.co.uk/forum/show...ighlight=timer
JS
Hi Shortbus,
JS
Thanks for the reply.
Can you recommend a particular timer? Also, why can't COUNT be directly utilized for this application?
in your previous code, add a # sign before W1 and post your results.
Count is not bad, but using a timer allow much flexibility, accuracy, and use less code space.Code:SEROUT 0,N2400,["Hertz: ",#W1,13,10]
