New guy here with both microcontrollers and PBP...
All I want to do is count the number of times a switch cycles over the timespan of a second and output it to a serial port. The serial output is working fine, but I'm getting only lines that read "Hertz:". I beleive that it's a problem with the registers, but I've tried various combinations without luck.
The switch is connected between pin 12 (DIP package) on the PIC and +5VDC, and my code looks like this:
Any suggestions? Thanks!Code:INCLUDE "Modedefs.bas" ' Have tried various registers. Here's what I currently have: ANSEL = %00000000 ' no analog inputs CMCON0 = %00000111 ' comparators off W1 Var word Loop: COUNT 1,1000,W1 SEROUT 0,N2400,["Hertz: ",W1,13,10] PAUSE 1000 GOTO Loop End
