GOSUB to do a pause?
Results 1 to 5 of 5
    Dec 2003
    San Diego
    Default GOSUB to do a pause?
    I have about 20 "PAUSE 20" calls in my program. If I change the code to do the pause with a gosub like this...
    gosub time20
    time20:
    pause 20
    Do I gain code space in doing the pause with a sub and just calling it each time?
    Basically I need to know if the single "pause 20" is longer or shorter than using a "sub" to do the same simple task.
    Is the simple call of the pause 20 vs the gosub call + the going and returning really any shorter?
    tcbcats
    Dec 2003
    Wichita KS
    Hello TCBcat,
    TBC>>Is the simple call of the pause 20 vs the gosub call + the going and returning really any shorter?<<
    You will not save code space. It may make your program easier to read...
    What you can do, is write a short program to do just that...
    If your gosube was doing more than just a "pause", then you have a greater chance of saving code space.
    It takes asm to place a marker, call a branch, and return to the marker. Since your subroutine is only doing one thing...."pause X" you lose.
    DWayne
    Ability to Fly:
    Pilots that are Flying:
    Dec 2003
    San Diego
    Smile Thanks for the info
    Thanks for the response....
    I thought the code space was almost the same since I was only doing the pause and nothing else.
    I'm not out of code space.... just needed to know if I was on the correct track..
    Cheers,
    tcbcats
    Dec 2003
    Wichita KS
    Hello TcBcats,
    TBC>>Thanks for the response....
    I'm not out of code space.... just needed to know if I was on the correct track..<<
    I wrote a very simple program that used only pause.
    Without the gosub, I got 50 bytes.
    With the Gosub, I got 52 bytes.
    Granted this was *only* one gosub. I guess I could have modified it to do 3 or 4 gosubs, and checked without a gosub too.
    Then i could have compared the size of the files and found out if multiple gosubs would save you space, and how much space.
    I may go to compilespot.com and check it out later today...during my lunch hour or something...
    I know in my borland compilers, it "compresses" the code if you have multilple duplicating things. I seriously doubt if PBP does <g>.
    Dwayne
    Ability to Fly:
    Feb 2004
    Germany
    Excuse my question, but doesn't tcbcats have a compiler?
  1. Graphic LCD with PICbasic pro
    By amindzo in forum mel PIC BASIC Pro
    Last Post: - 25th November 2012, 12:45
  2. Old and beyond help ?
    Last Post: - 11th December 2008, 16:23
  3. shifting problem
    By helmut in forum mel PIC BASIC Pro
    Last Post: - 31st August 2007, 07:11
  4. Output PIC module
    By freelancebee in forum mel PIC BASIC Pro
    Last Post: - 12th September 2005, 21:10
  5. ds1307 from f877 to f452 not work
    By microkam in forum mel PIC BASIC Pro
    Last Post: - 7th July 2005, 01:02
