Pass on serial data
Results 1 to 16 of 16
    Jun 2007
    Mansfield, UK
    Default Pass on serial data
    Hi, hopefully a simple one this time. i want my chips to startup and wait for a serial command. the serial data is (250),lineid then a string of bytes. the chip needs to send out the whole string on another pin but add 1 to the lineid. my code so far is this.
    serin2 porta.2,n9600,[WAIT(250),lineid,str tinput\8\0]
    lineid=lineid+1
    serout2 portb.4,n9600,[250,lineid,str tinput\8]
    this works fine aslong as i send 8 bytes after the line id. is there a way i can make it wait for 250 and the lineID then take whatever it can after that and pass it on?
    the chips will be linked to each other but they dont know how many chips there are and the string of bytes is (4 * number of chips) long
    also, how do i tell how many characters came in? is there a len() function like VB or ubound()? if not then i know a way i can work round it
    If you get 8 characters, you send them off...
    If you get 5 characters, how do you know that's all you're going to get?
    Is it a timed thing? Is the 5th character a CR or LF or something that would be recognizable?
    Jun 2007
    Mansfield, UK
    hmm. good point. i can make it so theres only 2 characters per chip and i can send something like (255) to show the end of the data.
    that means the chip reacts to [250],lineid,[1],[2],[3],[4],[255] AND [250],lineid,[1],[255]. how would i do that?
    I could analyse the STR macro, but i'm lazy today
    So you could still fill ALL variable array cells with zero before SERIN, and after SERIN checking which one is still = 0.
    Jun 2007
    Mansfield, UK
    yep. thats my workaround way :P i wont have to check them after though, just set them to the correct outputs
    One thing i could feel... the internal R0 variable should store the last character. Seems there's no counter variable. For that i would prefer to build my own routine BUT using the PIC USART... no SERIN/DEBUGIN/HSERIN at all.
    Jun 2007
    Mansfield, UK
    ill have a look into that later. isnt there a way of doing it with serin2? eventually i will need to use the timeout things too
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 04:47
  2. Read/Write Problem
    Last Post: - 10th February 2010, 01:51
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 02:21
  4. LCD + bar graph
    Last Post: - 5th October 2005, 14:50
  5. Sinus calculating !
    Last Post: - 28th November 2004, 23:56
