frequency meter in PBP
Results 1 to 10 of 10
    Quote Originally Posted by savnik View Post
    Because i want to add to code(in pbp) some others things , like to measure ADC.
    I try two days now without any result.
    Gave up on trying to write one yourself?
    You'll never get any fast counting done with a PIC and straight PBP (maybe 250khz), assembly might get you 10Mhz, if you use a 40Mhz PIC and you use one of the TMR inputs.
    However, if you take my idea (from the other thread), and use a pre-divider, you'll count much higher.
    And check this out....
    http://members.cox.net/berniekm/super.html
    Hi Skimask. If you study the Microchip AN592, you 'll see that a humble PIC 16C55 is counting up to 50 MHz!
    It use a clever technique to do that. But in PBP, I think it is quite difficult to obtain.
    Right, using the prescaler, I understand that, 10ns rise/fall time on the RTCC pin...works fine I'm sure (although I've never tried that particular project on that particular PIC).
    And that's what I was saying in the other thread about PBP. Use an external 74193 or something similar to pre-scale the count, and PBP should be able to count a fairly high number.
    Everything is around the sampling time and the accuracy you want not much. Depending of your PIC characteristic, 50MHZ is easy to do, 1500 MHZ??? i have some doubt, but with external hardware divider, there's no real problem.
    For high frequency... who want to use 1Sec time base? Nobody... 100mSec, 10mSec, 1mSec is more than possible.
    Nothing hard, nothing clever at all. Set a Timer as counter, Clear it, enable it, do you samppling time,m stop it, read it display it. 4 code line or so.
    @Savnik, Which PIC you want to use?
    Have a look to T0CKI, T1CKI. This will reveal tons of things.
    Jun 2006
    Quote Originally Posted by mister_e
    I have use external divider(:256)
    Yes , i use the below code(from AN592)
    asm
    enabletmr0      macro
            clrf    TMR0
            bsf     _trisabuf,3
            movf    _trisabuf,W
            tris    PORTA
    disabletmr0     macro
            bcf     _trisabuf,3
            bcf     PORTA,3
            movf    _trisabuf,W
            tris    PORTA
            movlw   0x10                ;initialize ddra
            movwf   _trisabuf           ;       /
            disabletmr0
            movlw   0x37                ;set the option register  - B'00110111'
            option                      ;to measure high freq.
            clrw
            enabletmr0                  ;enable tmr0
            call    delay5mS            ;wait for 5mS
            disabletmr0                 ;disable tmr0
            call    getfreq             ;get freq in fhi and flo
    ;delay1ms, is a very accurate 1mS delay for a 4Mhz clock.
    delay1mS
            movlw   197
            movwf   _count1
            nop
            goto    $+1
            goto    $+1
    dly1mS
            goto    $+1
            decfsz  _count1, F
            goto    dly1mS
            retlw   0
    ;delay5mS uses delay1mS to get a very accurate 5 mS delay
    delay5mS
            call    delay1mS
            call    delay1mS
            call    delay1mS
            call    delay1mS
            call    delay1mS
            movlw   4
            movwf   _count1
    tweek5mS
            decfsz  _count1, F
            goto    tweek5mS
    getfreq
            movf    TMR0,W              ;get the tmr0 value
            movwf   _fhi                ;save in fhi
            clrf    _count1             ;keep track of the toggles
    toggle1
            incf    _count1, F          ;inc for first
            bcf     PORTA,3             ;toggle the input
            bsf     PORTA,3             ;       /
            movf    TMR0,W              ;see if tmr0 incremented
            subwf   _fhi,W              ;       /
            btfsc   STATUS,Z            ;yes then skip
            goto    toggle1             ;no then toggle again
            comf    _count1, F          ;else complement count
            incf    _count1,W           ;and increment
            movwf   _flo                ;save in flo
            retlw   0                   ;return
    endasm
    i use 16f88.
  1. PBP Book
    By Bruce in forum Off Topic
    Last Post: - 4th October 2021, 12:55
  2. HPWM command and oscillator frequency
    By RussMartin in forum mel PIC BASIC Pro
    Last Post: - 8th March 2009, 22:41
  3. PULSIN for frequency meter?
    By PICante in forum mel PIC BASIC Pro
    Last Post: - 11th November 2008, 13:07
  4. frequency meter from 16f84a to 16f88
    Last Post: - 4th November 2006, 13:28
  5. inaccurate frequency using TMR1 PI18F452
    By nkarpovich in forum mel PIC BASIC Pro
    Last Post: - 14th October 2006, 16:22
