frequency meter in PBP
Results 1 to 10 of 10
    Jun 2006
    Default frequency meter in PBP
    The code below is for frequency meter 0-50Mhz.
    it is posible to import in pbp;
               processor  16F84a
               include    p16f84a.inc
    RAM        equ        h'0C'
    YES        equ        1
    NO         equ        0
    ;PORTA
    CONFIGA    equ        B'00010000'
    ;Port B
    CONFIGB    equ        B'00000000'
    PULLUP     equ        NO
    ;OPTION
    CONFOPT    equ        B'00100111'
    ;INTERRUPTION
    CONFINT    equ        B'00000000'
               cblock     RAM
    Temp
    Temp0
    TimeOut
    SaveW
    Result   : 4
    Count
    Char
    Thousand : 2
    BCD0
    BCD1
    BCD2
    BCD3
    N
               endc
               Reset      START
               IntReq     Intserv
    IncPre     macro
               bsf        PORTA,3
               bcf        PORTA,3
    Init       macro
               clrf       PORTA
               clrf       PORTB
    	Bank1
               Movlf      CONFIGA,TRISA
               Movlf      CONFIGB,TRISB
               Movlf      CONFOPT,OPTION_REG
               Movlf      CONFINT,INTCON
    	Bank0
               bsf        POWER
    InitMeasure macro
               Movlf      B'00000011',Thousand  ; Change: Thousand=(999)10
               Movlf      B'11100111',Thousand+1
               clrf       TMR0
               clrf       Result+1
               clrf       Result
    Ra3_out    macro
    	Bank1
               bcf        TRISA,3
    	Bank0
    Ra3_in     macro
    	Bank1
               bsf        TRISA,3
    	Bank0
    TJZ16      macro      file16,address
               Test       file16
               JZ         TJZ16_MSB_ZERO
    	nop
               nop
               goto       TJZ16_END
    TJZ16_MSB_ZERO
               Test       file16 +1
               JZ         address
    TJZ16_END
    ClearDisp  macro
               movlw      b'00000001'
               call       SEND_CMD
               call       T1mS
    DataOk     macro
               bsf        E
               bcf        E
    DDRam      macro      address
               movlw      0x80 + address
               call       SEND_CMD
    Disp       macro      charvalue
               movlw      charvalue
               call       SEND_CHAR
    RSCmd      macro
               bcf        RS
    RSChar     macro
               bsf        RS
    ShiftL     macro
               movlw      b'00011000'
               call       SEND_CMD
    T975us
               Movlf      .243 ,Temp0
    Loop975us
    	nop
               decfsz     Temp0,f
               goto       Loop975us
    ;Name    : Readprescal
    ;Function: Read the prescaler and store the result.
    ;Input   : tmr0 and prescaler
    ;Output  : Result +2 (tmr0) and Result +3 (prescaler)
    ;Call    : None
    ;Register: Count
    Readprescal
               Movlf      255,Count
               Movff      TMR0,Result+2
    INCREMENT
    	IncPre
               incf       Count,f
               CJE        TMR0,Result+2,INCREMENT
               movf       Count,w
               sublw      255
               movwf      Result+3
    ; Bin To BCD conversion ( 32 bit word -> 8 digits )
    ; Bin in Result, Result+1, Result+2, Result+3
    ; BCD in BCD3, BCD2, BCD1, BCD0
    Bin2BCD
               clrc
               Movlf      .32,N
               clrf       BCD3
               clrf       BCD2
               clrf       BCD1
               clrf       BCD0
    LoopBB
               rlf        Result+3,f
               rlf        Result+2,f
               rlf        Result+1,f
               rlf        Result,f
               rlf        BCD3,f
               rlf        BCD2,f
               rlf        BCD1,f
               rlf        BCD0,f
               decfsz     N,f
               goto       DecAdj
    DecAdj
               Movlf      BCD3,FSR
               call       BCDAdj
               Movlf      BCD2,FSR
               call       BCDAdj
               Movlf      BCD1,FSR
               call       BCDAdj
               Movlf      BCD0,FSR
               call       BCDAdj
               goto       LoopBB
    BCDAdj
               movlw      3
               addwf      INDF,w
               movwf      Temp
               btfsc      Temp,3
               movwf      INDF
               movlw      30H
               addwf      INDF,w
               movwf      Temp
               btfsc      Temp,7
               movwf      INDF
    ; Display Frequency stored in BCD3, BCD2, BCD1 and BCD0 (LSD)
    DispFreq
               DDRam      3
               swapf      BCD0,W
               andlw      0FH
               call       DispHex
               movf       BCD0,W
               andlw      0FH
               call       DispHex
               Disp       '.'
               swapf      BCD1,W
               andlw      0FH
               call       DispHex
               movf       BCD1,W
               andlw      0FH
               call       DispHex
               swapf      BCD2,W
               andlw      0FH
               call       DispHex
               Disp       '.'
               movf       BCD2,W
               andlw      0FH
               call       DispHex
               swapf      BCD3,W
               andlw      0FH
               call       DispHex
               movf       BCD3,W
               andlw      0FH
               call       DispHex
    ; Display hex digit
    ; input : w = hex
    DispHex
               addlw      -0AH
               SkipNC
               addlw      7
               addlw      3AH
               call       SEND_CHAR
    Intserv
               retfie
    ;____________________________________main_______________________
    START      Init
               call       INIT_LCD
               movlw      b'00001100'
               call       SEND_CMD
               movlw      b'00101000'
               call       SEND_CMD
               Movlf      226,TimeOut
               ClearDisp
               Disp       'F'
               Disp       'R'
               Disp       'E'
               Disp       'Q'
               Disp       'U'
               Disp       'E'
               Disp       'N'
               Disp       'C'
               Disp       'Y
               Disp       'M'
               Disp       'E'
               Disp       'T'
               Disp       'E'
               Disp       'R'
               Disp       ' '
               call       T1S
               call       T1S
               ClearDisp
               call       T100mS
               Disp       ' '
               Disp       ' '
               Disp       '5'
               Disp       '0'
               Disp       ' '
               Disp       'M'
               Disp       'H'
               Disp       'z'
               Disp       ' '
               Disp       ' '
               call       T1S
               call       T1S
               ClearDisp
               call       T100mS
               Disp       'F'
               Disp       ' '
               Disp       ' '
               Disp       ' '
               Disp       ' '
               Disp       ' '
               Disp       ' '
               Disp       ' '
               Disp       ' '
               Disp       ' '
               Disp       ' '
               Disp       ' '
               Disp       ' '
               Disp       ' '
               Disp       'H'
               Disp       'z'
    MEASURE    InitMeasure
               Ra3_in
               call       T975us
               nop
               nop
               nop
               nop
               nop
               nop
               nop
               nop
               nop
               nop
               nop
               nop
    GATE       TJZ16      Thousand,STOP
    WAIT       call       T975us
               Dec16      Thousand
               btfss      INTCON,T0IF
               goto       NO_OVERFLOW_TMR0
    OVERFLOW_TMR0
               bcf        INTCON,T0IF
               incf       Result+1,f
               JZ         INC_RESULT
               nop
               nop
               goto       GATE
    INC_RESULT
               incf       Result,f
               goto       GATE
    NO_OVERFLOW_TMR0
               nop
               nop
               nop
               nop
               nop
               goto       GATE
    STOP       Ra3_out
    READ       call       Readprescal
               call       Bin2BCD
               call       DispFreq
    TEST       Test       BCD0
               SkipNZ
               Test       BCD1
               SkipNZ
               Test       BCD2
               SkipNZ
               Test       BCD3
               SkipNZ
               goto       TIME_CONTROL
               clrf       TimeOut
               goto       MEASURE
    TIME_CONTROL
               incf       TimeOut,F
               JZ         MESS_TIME_OUT
               goto       MEASURE
    MESS_TIME_OUT
               ClearDisp
               Disp       ' '
               Disp       'A'
               Disp       'R'
               Disp       'R'
               Disp       'E'
               Disp       'T'
               Disp       ' '
               Disp       'A'
               Disp       'U'
               Disp       'T'
               Disp       'O'
               call       T1S
               call       T1S
               bcf        POWER
    LOOP_STOP
               goto       LOOP_STOP
    Yes, but why?
    Jun 2006
    Yes, but why?
    Because i want to add to code(in pbp) some others things , like to measure ADC.
    I try two days now without any result.
    Hi Niko!
    Assembly is much more faster than any other lanquage. The code you posted I think is from an old AN from Microchip, right? I studied few years ago. My opinion is that you will need a top class PIC with the highest XTAL to reach the needed speed. Is it worth really?
    Quote Originally Posted by savnik View Post
    Gave up on trying to write one yourself?
    You'll never get any fast counting done with a PIC and straight PBP (maybe 250khz), assembly might get you 10Mhz, if you use a 40Mhz PIC and you use one of the TMR inputs.
    However, if you take my idea (from the other thread), and use a pre-divider, you'll count much higher.
    And check this out....
    http://members.cox.net/berniekm/super.html
    Hi Skimask. If you study the Microchip AN592, you 'll see that a humble PIC 16C55 is counting up to 50 MHz!
    It use a clever technique to do that. But in PBP, I think it is quite difficult to obtain.
    Right, using the prescaler, I understand that, 10ns rise/fall time on the RTCC pin...works fine I'm sure (although I've never tried that particular project on that particular PIC).
    And that's what I was saying in the other thread about PBP. Use an external 74193 or something similar to pre-scale the count, and PBP should be able to count a fairly high number.
    Jun 2006
    Hi Niko!
    This is not from Microchip , but i have make the an592 from Microchip with a
    pic16f84a and prescaler and count until 1500 MHZ.
    Everything is around the sampling time and the accuracy you want not much. Depending of your PIC characteristic, 50MHZ is easy to do, 1500 MHZ??? i have some doubt, but with external hardware divider, there's no real problem.
    For high frequency... who want to use 1Sec time base? Nobody... 100mSec, 10mSec, 1mSec is more than possible.
    Nothing hard, nothing clever at all. Set a Timer as counter, Clear it, enable it, do you samppling time,m stop it, read it display it. 4 code line or so.
    @Savnik, Which PIC you want to use?
    Have a look to T0CKI, T1CKI. This will reveal tons of things.
    Jun 2006
    Quote Originally Posted by mister_e
    I have use external divider(:256)
    Yes , i use the below code(from AN592)
    asm
    enabletmr0      macro
            clrf    TMR0
            bsf     _trisabuf,3
            movf    _trisabuf,W
            tris    PORTA
    disabletmr0     macro
            bcf     _trisabuf,3
            bcf     PORTA,3
            movf    _trisabuf,W
            tris    PORTA
            movlw   0x10                ;initialize ddra
            movwf   _trisabuf           ;       /
            disabletmr0
            movlw   0x37                ;set the option register  - B'00110111'
            option                      ;to measure high freq.
            clrw
            enabletmr0                  ;enable tmr0
            call    delay5mS            ;wait for 5mS
            disabletmr0                 ;disable tmr0
            call    getfreq             ;get freq in fhi and flo
    ;delay1ms, is a very accurate 1mS delay for a 4Mhz clock.
    delay1mS
            movlw   197
            movwf   _count1
            nop
            goto    $+1
            goto    $+1
    dly1mS
            goto    $+1
            decfsz  _count1, F
            goto    dly1mS
            retlw   0
    ;delay5mS uses delay1mS to get a very accurate 5 mS delay
    delay5mS
            call    delay1mS
            call    delay1mS
            call    delay1mS
            call    delay1mS
            call    delay1mS
            movlw   4
            movwf   _count1
    tweek5mS
            decfsz  _count1, F
            goto    tweek5mS
    getfreq
            movf    TMR0,W              ;get the tmr0 value
            movwf   _fhi                ;save in fhi
            clrf    _count1             ;keep track of the toggles
    toggle1
            incf    _count1, F          ;inc for first
            bcf     PORTA,3             ;toggle the input
            bsf     PORTA,3             ;       /
            movf    TMR0,W              ;see if tmr0 incremented
            subwf   _fhi,W              ;       /
            btfsc   STATUS,Z            ;yes then skip
            goto    toggle1             ;no then toggle again
            comf    _count1, F          ;else complement count
            incf    _count1,W           ;and increment
            movwf   _flo                ;save in flo
            retlw   0                   ;return
    endasm
    i use 16f88.
  1. PBP Book
    By Bruce in forum Off Topic
    Last Post: - 4th October 2021, 12:55
  2. HPWM command and oscillator frequency
    By RussMartin in forum mel PIC BASIC Pro
    Last Post: - 8th March 2009, 22:41
  3. PULSIN for frequency meter?
    By PICante in forum mel PIC BASIC Pro
    Last Post: - 11th November 2008, 13:07
  4. frequency meter from 16f84a to 16f88
    Last Post: - 4th November 2006, 13:28
  5. inaccurate frequency using TMR1 PI18F452
    By nkarpovich in forum mel PIC BASIC Pro
    Last Post: - 14th October 2006, 16:22
