GP4 reliable output
Results 1 to 3 of 3
    Dec 2005
    Question GP4 reliable output
    Hi all,
    I need to use GP4 as an output on a 12F629. I know a pullup to Vcc works, but does anyone have a sure way to make it VERY reliable?
    Thanks for the help!
    Ron
    Quote Originally Posted by MARAD75 View Post
    Hi all,
    Ron
    What's not reliable about it? If the power is good, ground is good, clock is good, why shouldn't GP4 stay where it's supposed to?
    If you're that worried about it, keep writing to the port in your program.
    Dec 2005
    Smile Thanks skimask!
    I am concerned because I've had several different ideas about needing a pullup on this pin. I also found that without the pullup, it was suseptable to outside noise, especially RF. Would also cause the chip to lock up on occasion. The Pro manual seems to suggest the pullup is necessary. Then Jeff (from MELABS) said it is not needed on that chip! Who really knows?? I am going to use it anyway!
    Ron
  1. Help changing CCP3 output pin
    Last Post: - 15th July 2008, 02:30
  2. Bit Banging input to output on PIC16F876A
    By Bronurstomp in forum mel PIC BASIC Pro
    Last Post: - 26th June 2008, 19:50
  3. Serious Serial Situation Setbacks...
    Last Post: - 7th February 2007, 03:46
  4. Using LEDs as light sensors
    Last Post: - 30th December 2006, 22:19
  5. HSEROUT Newbie question/problem
    By Mark Scotford in forum mel PIC BASIC Pro
    Last Post: - 11th July 2006, 14:44
