How do you store 1 to 2ms servo pulses in a variable?
Results 1 to 25 of 25
    Question
    Hi, Skimask
    Back to our friend's program ... there's something " not told " ... cause it might give outputs ... even one of 3 or 4 !!!
    I'll give a try to that code on my breadboard ... or just use a 16F84 instead of my failsafe processor !!! Test board already made for 4 channels ...
    results tomorrow morning ...
    Hi, Skimask
    If I'm reading this right, the original poster, wants to sample 5 channels, and based on the value of the 5th channel (be it high or low or whatever), send the 1st 4 channels either out these 4 channels or those 4 channels...just like he said, a channel switcher.
    If that's the case, why bother sampling the other 4 channels? Just sample the 5th channel and use an output based on that decision as an input to a 2 input AND gate, along with the other input coming from channel X.
    2 74L08's (8 2-input AND gates), one PIC12Fxxx (or even 10Fxxx) should handle the 5th channel switching chores.
    Of course that's only if I'm reading the project correctly.
    Jun 2007
    SW England
    Chaps, this is dead interesting stuff. Not sure that I follow ALL what is being said, but still good nonetheless.
    In the previous post I mentioned that both turrets need four servos each to operate. Apologies... I mislead. Each turret needs just THREE servos - not four. The usual 'landing gear' switch (Ch.5) is to be the switch that changes the three R/C pulses at PORTA to either PORTB.0 to B.2, or B.3 to B.5.
    Using a 4MHz crystal/resonator I found the output gives a slight amount of servo jitter. Not much, but enough to be annoying. Swapping the Xtal to 10MHz does counter that unwanted jitter, but then the 'reverse' timing becomes out of sync (servo neutral shifts to somewhere other than neutral).
    I like the AND gate suggestion. But in this case the three servos which are not being operated are to be set to their neutral positions while they're sleeping.
    The downloadable version is PBP is limited to around thirty lines of code. I'm toying with the idea of purchasing the full-working version, but reluctant to splash out £££s if I can't even understand how to write simple code for gadgets such as this.
    You guys obviously know what you're doing so I'm hanging on to your advice.
    Ace': Good luck with the breadboard lash-up. And thanks!
    Same goes for you too, Ski'.... Thanks for all your input with this.
    Talking
    [QUOTE=Martin Peters;39803]
    > Good news ... your program works now ???
    > Héhé, PULSIN resolution changes with XTal freq. ... so @ 10 MHz ... neutral becomes 150 x 10 / 4 = 375.
    > Sending no signal to servos ( but servos always powered ) **might** leave them to their last position, if light effort like placing a gun barrel ... to be verified "live"
    > If you want to do ... you have to learn !!! no "pushbutton" miracle device here ...
    > You'll have to learn some basics of general program writing like flowcharts ... clearly told : to write down what you want to do and how you will do it.
    > Translating those papers into µP languages is the easier part of the thing ...
    > Those "gadgets" we play with have needed some years learning and experiencing ... and we still learn each and everyday !!!
    > Are you ready for that ???
    > do you really think we know what we do ??? ( LOL )
    My own advice is to look at what you want to do w/µP ... programming is like jogging ... stop for a while and It's a bit hard to recover the "cruising speed"
    Lightbulb
    Hi, Martin
    I did some diving into my Model Boats docs ... and found a Proton Basic Program Called "Turret1" ... I think you found it too !!!
    That raised in my mind the problem is much more complicated than we think ...
    - Use the minimum count of channels to drive from 1 to 4 Turrets
    - Have slow turret rotation
    - Move 1 to 4 Turret at the same time ( "Inverting The signal" good reason ... ).
    - couple by couple would be really nice ...
    - Have slow Barrels positionning too ...
    And overall keep a "driving board" that can be placed on a Classic Transmitter !!!
    So, ... I decided to re-Start the project on the Basis Here explained ...
    This could come in handy for things on R/C planes, bomb doors, flour bomb drops, tail hooks, etc.etc...not to mention extra turrets too...
    This might be fun...
    Talking
    Hi, Skimask
    "Turrets driver" is the only gadget I do not have realised for my planes yet ...
    As piloting + controlling turrets is not so easy ( LOL ) I'd planned to drive them with an IR source located on the ground.
    it's the moment to design it ... I've just finished an A26 Invader plan ...1/8.4 Scale
    Led-Machine guns,Electric gear control, bomb bay control and navigation lights are already built ...
  1. Thermo 7 segments - little problem
    Last Post: - 27th July 2013, 08:31
  2. RS485 bus - starting probem
    By wurm in forum mel PIC BASIC Pro
    Last Post: - 27th January 2010, 14:35
  3. one line led light make image
    By bioul in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 13:19
  4. HSERIN doesn´t work
    Last Post: - 29th July 2007, 15:23
  5. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 21:36
