GLCD and TouchScreen trouble
Results 1 to 18 of 18
    May 2006
    Del Rio, TX, USA
    Using some various piece of thin plasic, I can get no closer than 1/4". If I reduce the gap by 1/32", it blanks out.
    Capacitive touchscreen type thing? Or resistive?
    It's 4-wire resistive.
    May 2006
    Del Rio, TX, USA
    I don't know if it will make a difference in any help, but here is the code relevent to scanning the TS:
    XRaw VAR WORD
    YRaw VAR WORD
    Xp VAR PORTA.3
    Xm VAR PORTA.5
    Yp VAR PORTA.2
    Ym VAR PORTA.4
    ADCON1 = $0D 'Set only PORTA.0-1 Analog
    'Scan X
        HIGH Xp
        LOW Xm
        INPUT Yp
        INPUT Ym
        PAUSEUS 5
        ADCIN 0, XRaw
        LOW Xp
    'Scan Y
        HIGH Yp
        LOW Ym
        INPUT Xp
        INPUT Xm
        PAUSEUS 5
        ADCIN 1, YRaw
        LOW Yp
    and a schematic of the hookup:
    I keep going back to that grounding thing, static or EMI...
    Neither of the datasheets has any helpful hints as to what might be going on.
    Maybe try hooking a 'grounding wire' up to the touchscreen to the LCD frame, first with a 1K resistor (maybe less), then maybe a direct connection.
    I'm thinking it's some sort of static buildup causing the controllers on the GLCD to go nuts.
    Maybe try it sitting on a regular character LCD and see what happens? Not that a touch panel on a character LCD is any good, but it might lead to something...
    May 2006
    Del Rio, TX, USA
    I just happened to have a 4X20 breadboarded up with this project, and the TS has no effect on it.
    I'll look into the resistor idea tomorrow (or whenever I can get back to it this week). Not a lot of options to connect it to though, the lcd bezel is painted and there is nothing exposed on the TS. The "FrameGround" pin on the lcd is connected to GND. (I've also tried it not connected)
    SteveB
    Sep 2003
    Vermont
    I bet that the touch screen is creating an EM field due to the high frequency switching going on. Just for a test, take some of the static protective translucent poly bag material, and sandwich it between the two. If this doesn't relieve the problem, it should reduce the distance. You do have a wierd ground loop problem going on there. What is the hookup of your GLCD?
    Ron
    May 2006
    Del Rio, TX, USA
    As an update to my trouble shooting:
    I can't think of a good way to hook up the resistor, but along that idea, I took a piece of 12gauge (maybe 10) bare copper wire, created a U shape and laid that across the bezel on three sides, from the bottom, around the right edge, then to the top. Laid the TS on top of this and it worked.
    I am going to try and find a smaller wire and try that (or pound the 12gauge into a flat frame), possibly tonight if time permits. I'll also give Ron's suggestion a try at the same time. I was also thinking about an EM field, but not to much as that stuff is way over my head. BTW, the TS scan occurs every about every 10-20ms.
    As for the GLCD hookup, Here is the pin arrangement. (I just noticed i put a 2620 in the above schematic, I am actually using a 4620)
    Pin   		Connection
    1	VSS 	0v 		– Ground
    2 	VDD 	+5.0v 		– Supply voltage for logic
    3 	VO 	None		– Supply voltage for driving LCD
    4	RD 	PortC.2		- 8080 mode 1 = No operation 0 = Read
    5	WR 	PortC.3		- 8080 mode 1 = No operation 0 = Write
    6 	A0 	PortC.5		-
    7-14 	DB0-7	PortD		- Data Bits
    15 	CS 	PortC.4		- Chip select, Active L
    16 	RES 	PortE.2		- Controller reset signal, Active L
    17 	VEE 	None		- Negative voltage output
    18 	FGND 	0v 		- Frame ground
    19 	DISPOFF +5.0v 		- Display L: No Display
    20 	WAIT 	None
    Thanks for the help,
    From what you just described, it sounds like you just need a chunk of wire to run from the frame of the touchscreen (maybe epoxy it on there?) to the frame of the GLCD...and that's it. If there is an issue with EMI, then that direct connection would effectively drain the field away, for lack of a better phrase...
    Is the bezel of the touchscreen or the GLCD painted? Maybe that's why it isn't getting a good ground?
    Sep 2003
    Vermont
    Where does the frame ground go? (pin 18)
  1. Touchscreen question
    By manwolf in forum mel PIC BASIC Pro
    Last Post: - 27th June 2008, 04:49
