Quantasizing Formula
Results 1 to 4 of 4
    Jun 2007
    Red face Quantasizing Formula
    Hello,
    I set up a variable source of 0-25V and I intend to measure the tension and to show in one
    display. I learned on the command " how much level " that is to measure of
    0-5V (to See book " Experimenting with the PicBasic Pro Compiler " - Section
    4-18). somebody already used that command, with the due adaptations,
    to measure 0-25V? I already made 1023*/1250 to generate 5V approximately and
    I multiplied for 5, to give the 25V. The results starting from the reading
    of 6 or 7v they begin to present a mistake of volt hundredths that
    increase with the increase of the tension of POWER. I using a PIC16F877A. Below it follows the part of the reading AD.
    ADCIN PORTA.0, VALOR_AD0
    AUX1 = VALOR_AD0 */ 1250
    AUX2 = AUX1 * 5
    TEN_VOLT = AUX2 / 10000
    AUX3 = TEN_VOLT * 10000
    AUX4 = AUX2 - AUX3 '
    UNIT_VOLT = AUX4 / 1000
    AUX5 = UNIDADE_VOLT * 1000
    AUX6 = AUX4 - AUX5
    DECIMAL_VOLT = AUX6 / 100
    Here's a different way to do it that should be a little more accurate.
    https://www.picbasic.co.uk/forum/showthread.php?p=2010
    Just change the Res1 and Res2 variables to match your voltage divider.
    Jun 2007
    Thank you for the help,
    I tested his/her program but it presents the same problems of mine. With the increase of the tension of the source, 0-25V, the mistake is going increasing, that it begins with 1mV for 10V of the source and it arrives to 8mV with 24V of the source.
    Thank you,
    LLEEDD
    Hmmm, I don't see how you can be more accurate since:
    1. For 8bit ADC, each step is 25/255=0.098 Volts
    2. For 10bit ADC, each step is 25/1023=0.0244 Volts.
    May be you have to use an external ADC with more resolution.
  1. Sine wave power inverter
    By sougata in forum mel PIC BASIC Pro
    Last Post: - 23rd February 2017, 06:16
  2. Math Formula / Variable Problem! Help!
    By bwarp in forum mel PIC BASIC Pro
    Last Post: - 18th February 2006, 08:59
