JDM programmer
Results 1 to 5 of 5
Thread: JDM programmer
    May 2007
    Republic Serbia
    Question JDM programmer
    First Hi to all .
    Sorry for my bad English !!!
    I was make pilot programmer JDM and find something interest !!!
    On windows 98 SE it work 100% ok also like ICSP.
    It need little modification to program new PICMICRO but it's OK.
    But under windows XP SP2 it's not work OK !!!
    When I programming 16F84A @ 4 MHz case problem in write to PIC and
    also in ERASE PIC.
    When I programming 16F84A @ 20 MHZ it's work 100% OK.
    Also with 16F877A @ 20 MHZ it's work 100% OK.
    Somethig is not clear in my head ;-)
    Do somebody explain me that reasn ???
    Best regards to all
    skimask's Avatar
    skimask Guest
    Logged in under an ADMIN account?
    And I've said it before, I'll say it again, PICKit2...cheap, easy, supported, no problems...
    Mar 2006
    Hyderabad (India)
    Quote Originally Posted by phoenix_1 View Post
    First Hi to all .
    also in ERASE PIC.
    Best regards to all
    which driver software you are using? is it "picmicro"-- try using winpic800
    secondly- try replacing the electrolytic caps used. and ensure that Vpp is 12.5V .Otherwise use " icprog" there is a facility for delay adjustment I saw in " icprog" -- make it 15 or 20 - it should do your job.
    Sarma
    I agree!
    Icprog works perfectly with JDM on win XP
    Graham
    so does winpic800. i only use icprog for the 2 chips i have that aren't supported in winpic800. i use winpic800 for everything else. also, most jdm serial port problems are solved when using an external voltage source for vpp.
  1. Melabs U2 Programmer Command Line Options
    By Robert Wells in forum General
    Last Post: - 3rd July 2009, 02:11
  2. JDM type Programmer + WinPic800 (or whatever)
    By skimask in forum Schematics
    Last Post: - 10th December 2007, 12:12
  3. problems with USB programmer
    By malc-c in forum General
    Last Post: - 10th May 2007, 20:14
  4. JDM type programmer problem...
    By bearpawz in forum General
    Last Post: - 17th January 2007, 11:24
  5. USB programmer problems
    By uiucee2003 in forum USB
    Last Post: - 15th August 2006, 23:47
