How to read pulse from reed switch
Results 1 to 8 of 8
    May 2007
    Thanks! Wow, PBP is really powerful!
    I assume that as long as the voltage coming out of the reed switch is < 5V, it should be OK to connect the reed switch directly with any pin on the PIC.
    If I use the command
    COUNT PORTB.1,1000,w1
    I will be counting the number of pulses on pin1 in 1000 milliseconds.
    During the period of 1000 milliseconds, does the program 'pause' or does it continue to execute in the background, in other words, will any ON INTERRUPT commands execute during the 1000 milliseconds?
    May 2007
    The manual says "With a 20MHz oscillator it checks the pin state every 4us, thus I assume the program continues to execute during the 1000 milliseconds period of the COUNT command, or am I wrong?
    Quote Originally Posted by passion1 View Post
    Nope, the program stops during the counting.
    If you want the program to keep running, you have to start looking at interrupts and timers, etc...
    May 2007
    Skimask
    Thank you for the help!
  1. Cleaning up code
    Last Post: - 2nd December 2009, 08:14
  2. SEROUT WORD variable problem
    Last Post: - 19th April 2009, 12:20
  3. Replies: 3
    Last Post: - 13th September 2008, 18:40
  4. Changing declared variables names on the fly
    Last Post: - 16th December 2006, 07:34
  5. read the pulse of a bobbin
    Last Post: - 12th July 2006, 23:09
