How to read pulse from reed switch
Results 1 to 8 of 8
    May 2007
    Default How to read pulse from reed switch
    I am not sure if I need a frequency to voltage converter.
    I have got a device that transmits a pulse via a reed switch and I would
    like to interpret this output with my PIC16F877.
    Can I do this with PBP without needing a frequency to voltage converter?
    Quote Originally Posted by passion1 View Post
    So the output is a pulse that you need to COUNT?
    May 2007
    Yes! If I can count the pulse, then I can calculate the frequency using PBP
    (and would not need a frequency-to-voltage converter to convert to analog).
    In other words, how do I recognize a pulse from a reed switch directly and may I link the reed switch directly to a pin of my PIC, thus skipping the step of converting the output of the reed switch to a 0-5VDC signal?
    You answered your own question about COUNTing if you'd just take a quick look at the PBP manual.
    What's your voltages coming out of the reed switch?
    May 2007
    Thanks! Wow, PBP is really powerful!
    I assume that as long as the voltage coming out of the reed switch is < 5V, it should be OK to connect the reed switch directly with any pin on the PIC.
    If I use the command
    COUNT PORTB.1,1000,w1
    I will be counting the number of pulses on pin1 in 1000 milliseconds.
    During the period of 1000 milliseconds, does the program 'pause' or does it continue to execute in the background, in other words, will any ON INTERRUPT commands execute during the 1000 milliseconds?
    May 2007
    The manual says "With a 20MHz oscillator it checks the pin state every 4us, thus I assume the program continues to execute during the 1000 milliseconds period of the COUNT command, or am I wrong?
  1. Cleaning up code
    Last Post: - 2nd December 2009, 08:14
  2. SEROUT WORD variable problem
    Last Post: - 19th April 2009, 12:20
  3. Replies: 3
    Last Post: - 13th September 2008, 18:40
  4. Changing declared variables names on the fly
    Last Post: - 16th December 2006, 07:34
  5. read the pulse of a bobbin
    Last Post: - 12th July 2006, 23:09
