Now this depends on your definition of a 'Cycle', and whether it matches my definition.
If by a 'Cycle' you mean ONE increment of the Program Counter (1uS with a 4MHz PIC), then you can't actually do anything meaningful as PICBasics PULSIN takes more than one cycle to execute and exit, let alone follow it with an RCTime.
Therefore your definition of 'Cycle' must be something different... like the INPUT PULSE CYCLE perhaps, in which case yes then your definition will hold water since...
Pulsin Portx,1,...
...meaures the HIGH state of the Input 'Cycle', whilst...
RCTime Portx,0,...
...will measure the LOW state of the 'Cycle'. So technically it's still the same 'cycle'.
