Pulse measure
Results 1 to 3 of 3
Thread: Pulse measure
    Wink Pulse measure
    Hi Mel ...
    Just a ( very ) little challenge for you ...
    and what about using Pulsin Portx, 1, ...just followed with a RCTime Portx,0, ...
    you can measure all in only 1 cycle !!!
    Goes well ...and solution tested at 4 and 20 Mhz !!!
    Best regards,
    Now this depends on your definition of a 'Cycle', and whether it matches my definition.
    If by a 'Cycle' you mean ONE increment of the Program Counter (1uS with a 4MHz PIC), then you can't actually do anything meaningful as PICBasics PULSIN takes more than one cycle to execute and exit, let alone follow it with an RCTime.
    Therefore your definition of 'Cycle' must be something different... like the INPUT PULSE CYCLE perhaps, in which case yes then your definition will hold water since...
    Pulsin Portx,1,...
    ...meaures the HIGH state of the Input 'Cycle', whilst...
    RCTime Portx,0,...
    ...will measure the LOW state of the 'Cycle'. So technically it's still the same 'cycle'.
    Wink
    Hi, Mel
    Of course, the definition is applied to the input signal !!!
    have a nice day
  1. Pulse Capture and byte building
    Last Post: - 21st July 2009, 02:59
  2. Single digit 7 Seg LED clock - PIC16F88
    By thirsty in forum Code Examples
    Last Post: - 17th July 2009, 09:42
  3. Replies: 3
    Last Post: - 13th September 2008, 18:40
  4. measure pulse width 0-150Hz
    By kewetman in forum mel PIC BASIC Pro
    Last Post: - 15th November 2007, 22:38
  5. Pulse Frequency Multiplication
    By jamie_s in forum mel PIC BASIC Pro
    Last Post: - 21st August 2005, 11:39
