Multi Language Support on LCD ?
Results 1 to 6 of 6
    Jul 2005
    Default Multi Language Support on LCD ?
    Hi All,
    I am on a new project. I am using a 2x16 LCD. I have to make multi language support. I have a lot of way that goes to the solving. But I am searching more powerful and stable an algorithm. I can use ALGORITHM1, there is no problem. But I am using all codes again again that how much I am using language selection. So If I am using 3 lang. supports that means the size of code 3x(1 lang. code size). So Its not efficient. For example
    ;---------- ALGORITHM 1---------------
    ;for English
    if lang=0 then
    lcdout 254, 0, "English Menu"
    .... (All program codes)
    ;For German
    if lang=1 then
    lcdout 254, 0, "German Menu"
    .... (All program codes again)
    ;For Italian
    if lang=3 then
    lcdout 254, 0, "Italian Menu"
    But I want to develop ALGORITHM 2. But I have some problem. I want to use variables for the LCD's menus. So the user when the select the language I will change the variables's value to the suitable language value and I will stamp to the lcd's menu. But I didn't find how I can I do that. I mean:
    ;---------- ALGORITHM 2---------------
    ; LCD menu's items.
    ; we are adjusting LCD menu's language
    if lang=0 then
    Var1 = "Eng. Menu 1"
    Var2 = "Eng. Menu 2"
    if lang=1 then
    Var1 = "Ger. Menu 1"
    Var2 = "Ger. Menu 2"
    if lang=3 then
    Var1 = "Ita. Menu 1"
    Var2 = "Ita. Menu 2"
    lcdout 254, 0, Var1
    lcdout 254, 40, Var2
    .... (All program codes, only one)
    I hope I could describe my problems. what should I do? I need your valued ideas. Thank you so much.
    best regards
    Wink SEARCH Function
    Hi, Muskut
    A SEARCH with the "STRING" Keyword should show you that subject is not so new ...
    Routines will be the same , just the language will be different. So you could just store your strings in an external EEPROM and read from there. Choice is yours, 1 EEPROM/Language... Let's say you're using I2CEEPROM,
    I2CREAD SCL,SDA,Language, addr...
    or a Huge EEPROM + StartAddress offset.
    I2CREAD SCL,SDA,ControlByte, addr+Language...
    think about it... sure you can start from that.
    Jul 2005
    An external eeprom can be solving. But I am using 16F876A and I am using 4 bit LCD. And I want to solve this problem with only this devices. I have to develop a good algorithm.
    Thanks a lot for the answers.
    Quote Originally Posted by muskut View Post
    Silly idea...could program one '876A for each language, stack the chips, bend out the MCLR pin and put a toggle switch or a DIP switch going to each MCLR. The language you select is the MCLR that's allowed to rise after power on...
    So... store your text strings in the code space and use something around the above suggestion.
    http://www.pbpgroup.com/modules/wfse...p?articleid=10
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 19:14
  3. Play with LCD on PICDEM
  4. LCD Problem
    By karenhornby in forum General
    Last Post: - 19th June 2008, 11:43
  5. LCD will not start
