IR help
Results 1 to 8 of 8
Thread: IR help
    Dec 2005
    It depends on the protocol. If the protocol uses pulse width (or space width) modulation, PulsIn will work but some protocols are a bit more difficult. Sampling the pulsetrain every 25µS (or less) will work for almost all protocols, especially if you know the carrier frequency which will let you refine the numbers by using the nearest integral number of carrier cycles to match the sampled widths. What are you trying to accomplish?
    Hey Dave I'm working on a universal remote of sorts for some cameras.
    By sampleing the pulsetrain you mean like this?
    COUNT GPIO.4, 1, Pulsedata
    Dec 2005
    Quote Originally Posted by geckogrotto View Post
    There are both DIY and commercial devices that will do this. Of course, most folks who post here are wheel reinventors.
    By sampling the pulsetrain I mean checking the pin every 25µS (or less) and setting a bit in an array to indicate its state. You end up with something like...
    • 11111100000111000111000000111000111000000000000000
    which is an image of the pulsetrain where each digit represents a 25µS sample.
    IR receiver modules are active low, so you'll get an inverted output with 0s where there's IR and 1s where there's none.
  1. Replies: 17
    Last Post: - 12th April 2014, 02:17
  2. PIC16F877A pwm use for IR transmission
    By mcbeasleyjr in forum General
    Last Post: - 11th July 2009, 18:51
  3. Plz help in completing RC-5 IR remote lamp dimmer project
    By vu2iia in forum mel PIC BASIC Pro
    Last Post: - 3rd April 2008, 08:44
  4. PIC10F200 Automated IR Light Switch
    Last Post: - 3rd May 2007, 11:40
  5. how to get pic to pic communication
    By kinsiro in forum mel PIC BASIC Pro
    Last Post: - 30th August 2005, 17:12
