IR help
Results 1 to 8 of 8
Thread: IR help
    Default IR help
    Hey all, I want to use a IR receiver and record and output the data to the serial port from a TV remote.
    1st I want to know whats the best way to detect the signal? (what command)
    2nd will this "recording" alow me to be able to figure out how to repeat the signals back out?
    Italy
    Use a IR receiver. Make sure you use a IR receiver using the same
    carrier frequency used by your remote control.
    Example of IR receiver: Siemens SFH 506
    Datasheet:
    http://www.geocities.com/uirr/siemems-sfh506.pdf
    More about IR Remote Control Theory:
    http://www.sbprojects.com/knowledge/ir/ir.htm
    Best regards,
    Luciano
    Just for fun or to test a IR remote control:
    Beam with the IR remote in a digital camera or a cellular
    phone with camera and on the LCD of the camera you will see
    the light pulses. (CCD are sensible to infrared light).
    Dec 2005
    Quote Originally Posted by Luciano View Post
    Better yet use a broadband IR receiver that covers all the carrier frequencies used by all remotes (except B & O).It's very easy to use a PC soundcard (or chip) to view and/or record the output wave form.
    Ok will look over the sites and datasheets but whats the best way (command) to read the pulses in using picbasic. pulsin?
    skimask's Avatar
    skimask Guest
    Quote Originally Posted by geckogrotto View Post
    I've used pulsin to read Sony type IR commands without a problem...but, to each their own...
    Dec 2005
    It depends on the protocol. If the protocol uses pulse width (or space width) modulation, PulsIn will work but some protocols are a bit more difficult. Sampling the pulsetrain every 25µS (or less) will work for almost all protocols, especially if you know the carrier frequency which will let you refine the numbers by using the nearest integral number of carrier cycles to match the sampled widths. What are you trying to accomplish?
    Hey Dave I'm working on a universal remote of sorts for some cameras.
    By sampleing the pulsetrain you mean like this?
    COUNT GPIO.4, 1, Pulsedata
    Dec 2005
    There are both DIY and commercial devices that will do this. Of course, most folks who post here are wheel reinventors.
    By sampling the pulsetrain I mean checking the pin every 25µS (or less) and setting a bit in an array to indicate its state. You end up with something like...
    • 11111100000111000111000000111000111000000000000000
    which is an image of the pulsetrain where each digit represents a 25µS sample.
    IR receiver modules are active low, so you'll get an inverted output with 0s where there's IR and 1s where there's none.
  1. Replies: 17
    Last Post: - 12th April 2014, 03:17
  2. PIC16F877A pwm use for IR transmission
    By mcbeasleyjr in forum General
    Last Post: - 11th July 2009, 19:51
  3. Plz help in completing RC-5 IR remote lamp dimmer project
    By vu2iia in forum mel PIC BASIC Pro
    Last Post: - 3rd April 2008, 09:44
  4. PIC10F200 Automated IR Light Switch
    Last Post: - 3rd May 2007, 12:40
  5. how to get pic to pic communication
    By kinsiro in forum mel PIC BASIC Pro
    Last Post: - 30th August 2005, 18:12
