migrating to pic18f452 from 16f877a
Results 1 to 7 of 7
    Are you saying that you've actually had a 40MHz xtal or resonator directly work with one of these (18Fxx2) PICs (which would contradict the maximum Datasheet figures)?
    Yep, 40Mhz Xtal w/ 33pf cap's right next to OSC1&2 with a bit of a ground plane around the whole thing. Wasn't too reliable though. I'd touch practically anywhere the board and the PIC would lock up. That's when I read the rest of the datasheet (DS39564C) and found what you were saying about the 25Mhz earlier and fixed the whole thing.
    As far as the 55Mhz goes, that was a 13.824Mhz oscillator, and using the 4xPLL, but that was also running the chip on 6.5v.
    And this was the same chip that did 40Mhz with the external crystal. My guess is that this particular 18F452 chip was 'perfect', if not better, from the factory...a once in a lifetime good deal for me...not the norm obviously...
    Feb 2005
    Kolkata-India
    Default I recommend x4 PLL mode
    Almost all of my 18F452 designs are based on x4 PLL mode. That is I use a 10MHz crystal and get a 40MHz Fosc. They have never let me down.
    Sougata
  1. 16F877 vs. 16F877A
    By DavyJones in forum General
    Last Post: - 11th April 2009, 19:22
  2. help my bluetooth and PIC 16F877A?
    By slimpeng in forum mel PIC BASIC Pro
    Last Post: - 18th March 2008, 07:52
  3. communicating pic18f452 with pic16f877a
    By tamersoss in forum mel PIC BASIC Pro
    Last Post: - 13th July 2007, 20:54
  4. Clock connection to DS1802 from 16F877A
    By coyotegd in forum mel PIC BASIC Pro
    Last Post: - 3rd January 2006, 19:52
  5. 1st 16F877A program in PICBasic
    By Borisw37 in forum mel PIC BASIC Pro
    Last Post: - 19th January 2005, 05:46
