Need some experienced advice
Results 1 to 25 of 25
    Apr 2007
    Default Need some experienced advice
    Hello all,
    This is my first post on this fine forum. I have been registered for some time and have been reading when I could in preperation of a up comming project.
    A little about me...I am an Electroincs Technician by training but I work as a engineer because of my 20+ years of experience.
    Its been MANY years ago that I first purchased PBP. I have played with it but never did any real development. I am also a Basic freak! I am VERY familar with writing programs for the PC in Basic.
    My question is simple. There are literally HUNDREDS of different PIC chips out now. The project I have been asigned is a Keypad that controls a simple Motor controller circuit. So I don't need any fancy ADC or PWM features. What is a good solid chip that is cheap (comparable to the atmel chips) that will work for me.
    Now I know this is a tall order. I am just hoping that someone off the top of their head has some advise on were to start on this.
    Also, has anyone taken the course on Pbasic offered by RCG Research Inc? (I don't know if I can put a link here with out getting in trouble. So just google it you will find it.)
    I would intrested to hear of anyone experience with them.
    Thanks for any and all help....
    Once I get my feet wet I will help as around here as much as I can.
    Bill12780
    Quote Originally Posted by bill12780 View Post
    Hello all,
    A little about me...I am an Electroincs Technician by traning but I work as a engineer because of my 20+ years of experience.
    Bill12780
    HOLY CRAP!
    I hope you didn't pay for that!
    PBP - $250
    PIC Experimenter's board - <$200 for a good one
    A bit of time and playing = Priceless..
    That class = $2000+
    That's the problem with classes and a schedule...when you get done with them, pretty much all you REALLY know how to do is to build the projects they want you to build. You don't get a chance to play and build something of your own and REALLY learn from your own mistakes.
    Apr 2007
    HOLY CRAP!
    PBP - $250
    That class = $2000+
    Yea its expensive, But if you look you end up with about 900 bucks worth of stuff dev boards, the pro compiler etc...so I figured it was really only about 1000 bucks. I have NOT taken the class but was considering it. Hence my question....
    And I agree that I have learned more blowing things up then I ever learned in school.
    Thanks for the reply
    Bill12780
    Bill12780
    Glad to see you didn't waste your time.
    I can tell you that there's probably at least a dozen people or so around here that could probably do an equal if not better job at the same type of thing you were talking about...just change the initials and you're in there...in my case it would be something like jdgresearch. I should do that and charge half the cost.
    (Incidentally, I don't see $1,000 worth of stuff there...)
    Apr 2007
    Default Thanks for the reply
    If you have the expertise to do it...I would talk about a cherry gig! I got the 900 figure from them. They said it includes a dev board, compiler, editor a hand full of PIC's adapters, programers, sensors, motors, LED's all kinds of stuff basically a "everything you need to start" kinda thing.
    I did not really need it cause I can order a dev board from MEL and then upgrade my old version of PBP for 25 bucks. I already have a epic programer. But was looking at the USB one they have now.
    I also have the book by chuck helbuck(sp?). So I think I just need to lock myself in the basment and go to town!
    I know its not "approriate" but what do you guys think of the atmel stuff? I have heard its cheaper (cost per unit) and they are more "universal" in architecture (8051 or arm cant remember)
    Again, thanks for the input and the information...I love a good forum.
    Once I get up and running I will try and give my advise on the electronics side of stuff that is my forte.
    Bill12780
    Take a look at the compiler/dev board packages available at www.melabs.com and/or www.mikroe.com/en (not neccessarily mikro's compiler but the dev boards).
    Everything you need - you could probably get a 'grab bag' from Jameco for about $25
    Programmer - can't beat the USB PICKit2 direct from Microchip for $50-ish
    ATMEL vs. PIC - to each their own. I've messed with both. It seems to me that the architecture of the PIC is superior, but that's just me, and I started out with Z-80/8085/Intel types and then switched over.
    Apr 2007
    Default Ok but what chip to start with...
    Thank you all for the input on the class. Maybe its a good thing I did not go. (the world may never know!)
    But what about a good solid chip to start with. Do they make one with a built in RS-232? eventually my project will need to interface to a RF module that is controlled via RS-232.
    Like I said before the keypad project will be basically enter a code, allow the user to run a motor one direction or the other. (This is obviously over simplified because there will need to be several levels of codes for different reasons...)
    Save me HOURS of combing though datasheets and give me your opinions here!
    Thanks everyone!
    bill12780
    May 2006
    Del Rio, TX, USA
    Hi bill,
    I'll poke my nose in here and suggest the following:
    You can start with either the 16 or 18 series, but I would go with the 18 series. Disadvantages to doing that are the 18 series does not have any real small pin count options (like 8pin), and older books won't cover them as well.
    Some chips I like:
    18F4620 (40pin) or 18F2620 (28pin) - Has most of the available hardware functions (I2C, SPI, A2D, USART, Etc), loads of memory, and runs at 32MHz on the internal clock.
    18F4550 (40pin) or 18F2550 (28pin) - Similar to the above, but with USB support if you want to dive into that.
    Others will have their own preferences. A parametric search on Microchip's site will turn up a lot of options. Selecting the functions (like USART) you can't live without, memory size, pin count, and such will narrow the field nicely.
    You'll find lot's of help here, especially if you put the work in on your side.
    All the best as you start learning. Welcome!
    SteveB
    This depends on the number of I/O's you need...
    For up to 16 I/O's the cheap 16F628A is a good choice. (a) You don't need an xtal (unless you're doing async comms) because it works from it's own internal oscillator, and (b) it handles MCLR internally for you too. So all you need is a program, some volts and it works!
    I'll go with skimask's recommendation... forget any and all training courses. Equip yourself with a good programmer, latest version of PBP, a handfull of PICs, the Datasheets are free, a breadboard, good PSU, LCD with flying leads on it, and you're in business.
    If you don't know how to do something, then cobble together a little test program to display the result on the LCD. You'll learn more that way than any course.
    WHOA! Did I read that right! Did Mel go with MY recommendation? (head swelling, I'll let you know when the pressure gets to be too much )
    Learned all I can, I have...but a Jedi, I am not...
    I'd say go with a PIC18F4550 and associated hardware, programmers, etc.
    You can get it in a DIP package (which means you can mess with it on a solderless protoboard), it's got plenty of I/O and memory, plenty of functionality, and it's got USB ports...which, no, they aren't really for a beginner, but they are there for future toys.
    Apr 2007
    Default WOW lots of good help
    I cant tell you how nice it is to get some good help as a noob on a forum. It is RARE! I read a sticky from Melanie about this and it must have worked!
    I do appreciate all the suggestion on chips. I will get the datasheets tonight and look them over.
    If you all can handle it. I do have more questions....
    1) How big a problem is it moving from one chip to another. Example. Lets say I choose one chip and find I don't have enough space for the program. Are there "other" versions of the same chip with more memory? I mean pin for pin compatible? Otherwise, how do you even begin to estimate how big your program is going to be?
    2) I mentioned my project is keypad based. Have any of you heard of or know what the advantages are to using a 74c922 keyboard decoder? I have seen other designs that dont use them and some that do? Like I mentioned before I am an electronics guy (mostly analog stuff) so I have never used a 74c922. I do understand that the decoder will reduce Inputs needed on the PIC and the debounce is controlable. I guess what I am asking is more from a "Coding" point of view/use with a PIC perspective.
    3) What do you all think of the MEL lab-x1 dev board? I feel when making purchases its always best to ask the man(or woman) that owns one. Also, is my epic programer still gonna be ok with the new chips. Or should I invest in a USB programmer.
    4) What about the PIC-AXE with the bootloader? If I am not mistaken would this not me similar to like having a Jtag port? As Ricky Ricardo would say "splain it to me"
    Man, I cant tell you how refreshing it is to go to a forum and not get slammed for being ignorant...(Ignorant has in un-informed---not stupid that is different!)
    Thanks again, and if anyone needs electronics help I will do my best!
    Off to the MICRO-CHIPS website for some datasheets!
    bill12780
    1 - Piece of cake... Most of the PIC's in the same family are (i.e. 28 pin for 28 pin, 40 pin for 40 pin, and so on), 99% compatible at the pin level with a newer PIC having more functionality on the same pin or set of pins, about 95% compatible at the PBP level, and probably around 80% compatible at the assembly level. For instance, I built an MP3 player, started off with a 16F877A, moved to an 18F452, then an 18F4620. No change in hardware, and minor changes in the PBP source.
    2 - The 74C922/74C923 aren't that easy to find anymore and they're a bit expensive. You could do the same thing with a much cheaper 18 pin PIC, and program it yourself to include things like shift keys, control keys and things like that. Can't do that with a 74C922...
    3 - I don't own a dev board of any sort. There is nothing wrong with any of the boards sold by MeLabs, they're all good...however, I do believe you get a better deal with the ones from www.mikroe.com, the EasyPic4.
    And I (and others will say the same thing) think one of the better programmers out there is the PICKit2, upgradeable, support direct from Microchip, it's USB, self powered, and so on. I just bought one, works great.
    4 - PIC-AXE with a bootloader - all that means is that you can reprogram the chip without having a programmer, usually all you need is a serial port or something similar, but at the expense of a couple of pins and some code space. With time, you could make your own bootloader...or you could buy or download 'bootloader' code from various places on the 'net.
    4a - and yes, it's similar to a JTAG port.
    Mar 2006
    Pennsylvania, USA.
    Default Lab X USB
    I can highly recommend the LabX-USB board from ME Labs. It is set up for the 18f4550, so you can develop USB applications, it has RS-232 on board, and you can add things like Dallas 1-wire temperature sensors, etc. It has sixteen push buttons on it, so you can set up your keypad project right off the bat. It works with the EPIC programmer, but when I got my new computer I upgraded to the USB programmer, and am very happy with it. (It's getting hard to find an LPT port anymore.) The EPIC plugs right into the development board, you don't have to remove the chip to program it. I do like Melanie suggested, I output to the LCD to debug my programs, and there are a few LED's on the board if you just want to toggle something. I usually use one for a 'heart-beat' so I can tell if I screwed up and confused the microprocessor!
    For quick one-off projects I like ME Labs proto-boards. I have one I put a ZIF socket on that I can put little chips like the 16f88 in if I want to try something fast and easy. Hope this helps.
    Jerry.
    If your oscilloscope costs more than your car...
    Apr 2006
    New Hampshire USA
    Smile My opinions only.
    Hi Bill,
    Welcome to the forum.
    EasyPIC4 Development System $120
    Get the accessories too while you are ordering.
    http://www.mikroe.com/en/tools/easypic4/
    Forum post example:
    Development Board Recommendations
    http://www.picbasic.co.uk/forum/showthread.php?t=5609
    Forum post example:
    keypad routine
    http://www.picbasic.co.uk/forum/showthread.php?t=6230
    “PICKit 2”, is one of the the best choices for a beginner, less problems with side-effects.
    My opinions only.
    -Adam-
    May 2006
    Del Rio, TX, USA
    I do own one, and I can not complain. Solid product. That said, I think the EasyPic4 is much more for the money. Lots of good feedback from those who own one as well. (I'm sure Steve, a.k.a. MisterE, will chime in here eventually).
    SteveB
    Hi Bill,
    My 2.5 cents worth.
    Dev board = Box of $4.00 breadboards from allelectronics.
    Programer = PICKit2
    Chip = 16F877A no USB though
    Quote Originally Posted by SteveB View Post
    SteveB
    YES indeed EasyPIC 4 all the way! And buy a couple of their EasyProto board adapter as well...
    6 bucks it's nothing... it just don't worth to build your own now...
    But yeah, assuming a tighter budget, PICKIt2, one breadboard and few parts it's a smart choice as long as the bill of material is at least under EasyPIC4 which should come with a 16F877A.
    Apr 2007
    Default Made the move!
    OK everyone here is what I did.
    I ordered my upgrade and manual for PBP (Should be here anyday)
    I went with the Microe EasyPic4 with a few of the proto board adapters.
    I have pretty much decided that I am going to use a PIC16f876 going to order some of those today.
    I can not tell you how much I help you all have been. I would have been totally screwed if you guys had not spoken up and gave me some good info to work with.
    I am sure once the coding begins I will be back. I will try and get in here every couple of days to see if I can help with any Electronics issues.
    Thanks again! Its more appreciated they you know!
    Best Regards,
    Bill McFarland
    Jun 2005
    Up the bush, Western Plains, NSW Au
    Hi Bill,
    Yeah the folks in here are sure to be happy to help in any way.
    Also, don't be at all afraid to ask some stupid question (that comes from experience, believe me!)
    I've been a basic freak for yonks too, started with the VIC-20, remember them? Did some assembler with the 6502 but long since forgotten.
    Anyway, enjoy the forum and the camaraderie(? spelling?) in here.
    Last edited by muddy0409; - 19th June 2007 at 20:04. Reason: Spelling (a-bloody-gain!
    Peter Moritz.
    New South Wales,
    Australia.
    Best Regards,
    Bill McFarland
    All good, solid choices... Just remember to start off simple (stupidlike? ) and work your way up. Play with everything, not only code, but config settings, learn how to manipulate them, mess with interrupts, get a button or two to work, move LEDs around (not the leds themselves, but the lighting thereof), talk back and forth with a PC thru the serial port...and so on and so on. Before you know it, we'll be asking you for answers...
    Quote Originally Posted by muddy0409 View Post
    WOOHOO, those where the days
    I can't imagine there's a lot of people here reminding that we used regular audio cassette to store/read our programs. This sure make me feel an old guy
    I begun with TI-99/4A, then VIC-20, TRS-80, COCO-2, Commodore 64, 128, then 8080, 8088, etc etc ...
    That's french and seems to be almost same in English..
    http://www.thefreedictionary.com/camaraderie
    http://www.thefreedictionary.com/comradery
    malc-c's Avatar
    malc-c Guest
    Steve, you and me must be of the same generation
    I started with the Sinclair ZX81 (I think it was called the Texas 81 in the US ?) - was amazed that you could get a full "traditional" startrek game with an 8 x 8 galaxy, black holes, bases etc all in 1K of memory !
    As for the audio tapes, I remember playing them on a hi-fi and you could hear the actual pitch changes representing the 1's and 0's - baud rate of about 10 I guess
    LMAO... I had the Zx80... just forgot to mention
    I still have the VIC-20 schematic and programming book
    Apr 2007
    Default wow....
    I feel so at home here.
    I too owned a Timex-Sinclair a vic20, 64, ti-99 4/a and I remember loading programs from my cassette player! Rember how kewl it was to load the program and then 30 mins latter you could come back program AND listen to your favorite band!
    then moved to a sanyo mbc-550 (pc clone, dual 5 1/4" 720K floppies! I was the man back then! first one of my friends to have a 1200 baud modem we all had 300's then)
    Anyone one any apple stuff from back in the day. I had a apple IIe, a IIc and a lisa...Never bought a mac though...
    We all must be 30-40 somthings....
    bill12780
    Apr 2006
    New Hampshire USA
    Unhappy Hey
    I too owned a Timex-Sinclair a vic20, 64, ti-99 4/a and I remember loading programs from my cassette player! Rember how kewl it was to load the program and then 30 mins latter you could come back program AND listen to your favorite band!...
    ... We all must be 30-40 somthings....
    bill12780
    Hey! Some of us were 30 something when we got the VIC-20!
    -Adam-
  1. GPS module - advice needed
    By flotulopex in forum General
    Last Post: - 21st July 2009, 22:05
  2. Need "PIC16F84A" Controler schematic Advice...
    By Kyo_89 in forum Schematics
    Last Post: - 28th May 2009, 00:03
  3. Advice on frequency measurement to 30MHz
    By Andy Wood in forum mel PIC BASIC Pro
    Last Post: - 27th March 2009, 05:23
  4. Your OTP advice?
    By truvahorse in forum mel PIC BASIC Pro
    Last Post: - 28th June 2008, 17:37
  5. Advice needed on 'neat' Project!
    By vacpress in forum mel PIC BASIC Pro
    Last Post: - 11th February 2007, 07:21
