Another idea if you do not want the extra hardware and will give up a little bit of resolution.
I had the same problem in the past, using a LM34 and a pressure sensor with an output of 1 to 5 volt = 0 psi to MAX. Left the VREF at VDD. OK for the pressure sensor, took the ADC value from the LM34 *2. This gave a 2 degree resolution for the temperature though, and I can not remember but I think the ice water test was off a degree or two also.
Not perfect but the pressure was the critical thing on that application.
Thanks for the reply everyone.
I am not very concerned about using extra hardware as much as I am about the accurate readings from the sensor. If I use separate external A/D chip for each sensor would this allow me the freedom to select the suitable Vref for the various sensors or will I still be restricted to choosing one Vref?
Lets say I use an external A/D Chip this means that I can use different Vref for each sensor. Now what Vref do I choose for the PIC18F6520. Do I simply use Vref = 5V? This is where I am getting confused. Can you please help me. any suggestion is greatly appreciated. Thanks
-Srig
If I am going to be using an External ADC for each sensor, then I guess do not have to connect a voltage to Vref for the PIC18F6520.
For example, If I choose the LM34 and connect this device to an external 8 bit ADC. What type of data will I be getting from the ADC, and how will I be able to decifer it on the PIC side?
Using an external ADC.
Make all of the IO's digital.
This may get me in trouble but I am going to refer you to a Basic Stamp document.
http://www.parallax.com/dl/docs/books/edu/ic.pdf
Goto the section "Experiment #4: Continuous Process Control"
The Basic Stamp is built around a PIC but does not have ADC. The code is close enough to understand what is going on.
The above "Experiment #4: Continuous Process Control" is using a LM34 and a n ADC 0831.
If I told you how to do it, it would just be the same thing as in the document, almost. There are other good ideas there too.
