Using EasyHID with VBExpress 2005 (maybe .NET as well)
Results 1 to 11 of 11
    Feb 2007
    Thanks for that, it now works.
    I expected it to be related to not using a fixed length string, however I had only tried to set the strings to Null rather than a load of spaces.
    Anyway I have found that using the following is easier than counting how many time you press the spacebar
    Dim VendorName As String = New String(CChar(" "), 16)
    Also in the code you posted I don't think that you need to call "hidGetHandle" as you already have that in the variable "pHandle".
    here's a way to assign a fixed format string in dotnet
    [HTML]<VBFixedString(15)> Public VendorName As String[/HTML]
    you still need to load with character it so far... don't forget the Imports Sytem
    Guys over there send me few links. Load of thing to learn/try with this new .NET. (marshallxxx, exception.. syntax, InteropService.. etc etc etc). Especially when dealing with API
    I've also found few nice .CHM and .PDF on VB.NET and Express... RTFM sessions will begin... when i'll wake up. <hr>
    EOM
    Amr Bekhit has modified it a little bit and added some documentation as well
    USB HID Template for Visual Basic 2005
    http://www.helmpcb.com/Software/USBHIDVB/USBHIDVB.aspx
    Thumbs down easyHID problems in c #
    Hi i from argentina and my english is not very good...but i have a question ....anyone has try to use mcHID.dll (easy HID) in Visual C# ??
    any help is welcome
    I have tried to write an application in c # but I have not worked
    hello as they are, I could fix most errors in the program but were 5 not understand .... anyway I leave the program so that you take a look.
    and finally the mistakes that I generated Visual C #
    Error	1	No se puede pasar '<this>' como argumento out o ref porque es de sólo lectura	C:\Documents and Settings\Flia. Moyano\Escritorio\Electrónica\easyHID c#\Form1.cs	32	37	easyHID_VB.net 2008
    Error	2	'object' no contiene una definición de 'OnPlugged' ni se encontró ningún método de extensión 'OnPlugged' que acepte un primer argumento de tipo 'object' (¿falta una directiva de uso o una referencia de ensamblado?)	C:\Documents and Settings\Flia. Moyano\Escritorio\Electrónica\easyHID c#\Module1.cs	121	16	easyHID_VB.net 2008
    Error	3	'object' no contiene una definición de 'OnUnplugged' ni se encontró ningún método de extensión 'OnUnplugged' que acepte un primer argumento de tipo 'object' (¿falta una directiva de uso o una referencia de ensamblado?)	C:\Documents and Settings\Flia. Moyano\Escritorio\Electrónica\easyHID c#\Module1.cs	125	16	easyHID_VB.net 2008
    Error	4	'object' no contiene una definición de 'OnChanged' ni se encontró ningún método de extensión 'OnChanged' que acepte un primer argumento de tipo 'object' (¿falta una directiva de uso o una referencia de ensamblado?)	C:\Documents and Settings\Flia. Moyano\Escritorio\Electrónica\easyHID c#\Module1.cs	129	16	easyHID_VB.net 2008
    Error	5	'object' no contiene una definición de 'OnRead' ni se encontró ningún método de extensión 'OnRead' que acepte un primer argumento de tipo 'object' (¿falta una directiva de uso o una referencia de ensamblado?)	C:\Documents and Settings\Flia. Moyano\Escritorio\Electrónica\easyHID c#\Module1.cs	133	16	easyHID_VB.net 2008
  1. Replies: 4
    Last Post: - 5th November 2008, 17:21
  2. Problem with enumeration and EasyHID
    By jizyjuice in forum USB
    Last Post: - 9th April 2007, 21:40
  3. EasyHID and VB.net
    By NL2TTL in forum mel PIC BASIC Pro
    Last Post: - 14th September 2006, 06:40
  4. HIDMakerFS versus EasyHID
    By Demon in forum USB
    Last Post: - 15th August 2006, 09:01
  5. Replies: 0
    Last Post: - 5th September 2005, 10:09
